Author Topic: Technical questions  (Read 1277 times)
lsuarez011
Technical questions
« on: September 28, 2023, 02:55:30 PM »
First of all, thank you very much, the forum has too much good information. I am from Colombia. I have a Kymco Agility 125 with digital tachometer model 2016, the bike is excellent.
I have the following modifications installed: Bore to 150 cc. Clutch with red springs (2000 RPM).
I would like to know, you have mounted PWK type carburetor or its better use a 26mm carburetor? what weight of roller or slider can I use to have a performance more in line with the strength of the clutch?
Thanks
Re: Technical questions
« Reply #1 on: September 28, 2023, 07:15:39 PM »
Welcome here!
Concerning carbs:
both types are available in 26mm, which, correctely jetted, seem to be enough for 150cc
-with a PWK carb you might have a little bit better performance
-a CVK carb is more reliable and has better fuel economy
There is no magic formula which is spoken over a carb and makes it work wonderousely.
Only road testing with different jets is a way to success.
Maybe watch this link...
https://www.kymcoforum.com/index.php?topic=31762.0
About roller weights:
Again no easy way to find for YOU the right
a) weight
b) shape
c) performance
..as a start leave original rollers in your CVT and testride..with your carb of choice
You are not happy with your taking off from start
- try lighter rollers
You want a more quiet cruising,
- try heavier rollers or Dr.P gliders
Maybe watch this link for some inspiration..
https://www.kymcoforum.com/index.php?topic=30655.msg214654#msg214654
« Last Edit: September 28, 2023, 07:27:48 PM by Ruffus »
lsuarez011
« Reply #2 on: September 28, 2023, 07:37:55 PM »
Welcome here!
Concerning carbs:
a) weight
b) shape
c) performance
excellent information, I really appreciate it, I will look for the CVK. but what size do you recommend, go to 30mm or 26mm?
With respect to the "rollers" I will try something lighter, currently I am opening at almost 4500 RPM, I am looking for something that opens at less RPM.
« Last Edit: September 28, 2023, 08:04:34 PM by lsuarez011 »
« Reply #3 on: September 28, 2023, 09:36:23 PM »
Best way would be to try it on the road with both.
Aftermarket pieces are inexpensive, even I think 26mm are enough for 150cc.
