Author Topic: Are DrPulley sliders prone to flipping in LGE5 ( post 2011 ) variators ?  (Read 2066 times)
Ericson
Hi !
Recently I got a problem with rear wheel spinning while on center stand on idle RPMs. I traced the problem to chinese 20x12 13g sliders that where flipping inside the LGE5 Variator Movable Drive Face with LGE5 ramp plate ( post 2011 DT300i  CVT config )- one flipped slider was enough to lock CVT in "second" or "third" gear and made any acceleration from standstill a challange  :P
That's a pitty because when they worked, the scooter had a perfect gearing for my taste which I can't replicate using rollers.  :'(
I'm thinking about purchase of Dr Puller 20x12 13g set but I'm wondering if they have any better anti-flipping capabilities ?  ::) Real life reports would be much appreciated from you guys  ;D
thanks
« Last Edit: November 05, 2023, 09:59:29 AM by Ericson »
mousejunks
I don't have any experience with Dr Pulley sliders, but I did recently have a worn/stuck roller which caused very similar problems by locking the variator in 'gear'. https://www.kymcoforum.com/index.php?topic=33745.30
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
No problems either with NO NAME or original "TechPülley" squares. Best results on small scoots were with spanish made rollers, inexpensive.
Had once to try a set of yellowish/ orange, similar to DrPs squares, but tested its material and found it too soft to apply in my/any scoot.
See link
https://www.kymcoforum.com/index.php?topic=30655.0
On bigger scoots, 350 and up I've used only genuine DrPs or TechPülley over last five years. No problems on about twenty/ thirty scoots so far.
Additionally I polish and "dremelfit" ramps AND variator housing to avoid such complications.
See link
https://www.kymcoforum.com/index.php?topic=33615.0
I think its also a benefit to use only BANDO or MITSUBOSHI belts in our CVTs plus unglazing clutch pads once in a while.
Your mentioned flipped slider might have been caused by a weak counter pressure spring or sliders too narrow, 0.5mm is enough to topple.
« Last Edit: November 04, 2023, 08:08:16 PM by Ruffus »
I've used Dr Pulleys on a 163, 279 and 399 cc scooters with good results.
One does nave to be careful during the reassembly process - to ensure that the weights do not flip over - if you can do that, they should work fine.
