Author Topic: 22K valve adjustment on my Like 150i  (Read 243 times)
« on: November 15, 2023, 02:29:32 AM »
I last adjusted the valves on my like at 11,500 miles.  The recommended interval is every 5K miles but I didn't check them again until today at 22,000 miles.  I could have waited another 5 or 10K as they barely needed adjustment.  The Intakes had loosened to .005 Inches from .004 so I adjusted them.  The exhausts had not moved so I left them alone.
As with many modern scooters removing and replacing the plastics is a PITA while the actual mechanical work is pretty simple.
