Author Topic: MXU 500 Speedometer  (Read 1209 times)
tankardus
MXU 500 Speedometer
« on: November 20, 2023, 09:41:55 PM »
Hi everybody just picked up a 2012 MXU500.  Has a digital dash.  Speedometer and odometer don't work, RPMs work, everything else on the display works.  Where do I start?
« Last Edit: November 20, 2023, 10:43:11 PM by tankardus »
Bratman2
Re: MXU 500 Speedometer
« Reply #1 on: November 28, 2023, 01:13:31 AM »
There is a little magnet sender on the 450i units. It is located by your left ankle when setting on the machine. Pull that cover off and you should see the wires for it and connector if they are the same for a 450 and 500. Think there is a magnetic piece that slides inside. You can try cleaning it first. I would do that and mine would start working for a very little bit of time. Replacement cost me like $60.00, best I can remember.
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
