Author Topic: Kymco Agility 125cc Stall and problems  (Read 420 times)
GarryM
« on: November 24, 2023, 12:30:29 PM »
Hi, my Agility (22k km) has stalled twice over the last 3 days, first time it started again after a couple of presses but today it just spluttered and stopped when tried to start, I then started pushing it home as only a few blocks away, about half way back I tried starting it again and it started but the engine light stayed on. Drove home, went inside for a little bit and went to start again (added a little oil it wasnt empty about half way up the dipstick) and it started fine and the engine light didn't come on. Both times this happened was in the rain although I never went in any deep water. Any ideas on what is happening?
Re: Kymco Agility 125cc Stall and problems
« Reply #1 on: November 24, 2023, 02:13:07 PM »
@GarryM welcome here!
In this case I would start with basics, like..
METIN  box out...
At carburator model.
-check sparkplug, cap and cable to coil
-check fuel support, fuel filter, lines
-airfilter out
-vacuum hoses all plugged
-see if it helps  when you open your fuel cap
-side stand switch if mounted
-starter switch, kill switch
-this two thin cables to ignition coil
-front panel off, check all relais
-is all electric working properly, lights, brakelights, indicators?
At injection model  the same plus checking connectors/cable to CO -sensor.
Pls see all this and come back to ask.
« Last Edit: November 25, 2023, 11:41:51 AM by Ruffus »
aschrauth
« Reply #2 on: December 03, 2023, 01:05:29 AM »
Try replacing your CDI
Kymco 125cc
Wolf Rx50 BBK 80cc
JJJoseph
  • Kymco Sento
« Reply #3 on: December 07, 2023, 08:51:18 AM »
Give us a break and tell us what year and model Agility we're talking about. Don't be shy - tell us everything, every detail. It makes a big difference!  Otherwise we're simply guessing.
