You all know that any project plans change more than once before completion of the project. Well, now we're on to plan C.
Met with a retired metal worker and welder tonight to discuss what I have figured out so far. He is actually the husband of one of my wife's female friends who was in that career.
He had a lot of insight that was helpful given that he was here and looking at the situation in person. I was hoping he would assist with any tube bending and/or welding. But he doesn't currently have the equipment for working with stainless steel bending or welding. He did say he really liked what I was coming up with so far but had some suggestions to consider.
He considered my plan for bending the tubes but stated that most shops would do better to put a V cut where a bend is needed, bend the tube and weld it at the resulting seam. He also said the shop would put a gusset at the bend to make it stronger. That does resolve the issue of the tube deforming at a curved bend. He told me that the old adapter I was thinking of using would add a bit of complication since it is mild steel and not stainless steel like all the new metal I am using. It can be welded but the weld is not as good and the mild steel would be subject to rust as time passes. He also had a really good idea that the hitch frame tubes can be slotted and the rear plate that the Uni-Go receiver is bolted to can be fitted into the slots and welded to make it even stronger at the end. He did encourage me to add in the hanger bar as I was considering. So based just on this much information and recommendation I came up with 2 alternate setups shown in these pics.
The first is simpler but not quite as elegant yet might be stronger with only one welded bend involved with a bigger gusset. The second is closer to the original frame shape I was thinking of but will require 2 bend/welds and gussets.
https://photos.app.goo.gl/MUwNbt2vpTvTceJd8He thought my idea of using square U-bolts was good. I asked about the issue or possibility that putting a hole and using bolts in the OEM rear bike frame might damage the integrity of the cast aluminum. As he looked at the OEM rear bike frame he immediately assured me that the OEM frame is a bit over-built and well strengthened and that drilling a hole in the upper frame on each side and a hole on the lower frame on each side where the square tubing lays against the bike frame would be no issue at all. He said he likes to do a little overkill on his projects and would have no hesitation to use hardened (grade
![Cool 8)](https://www.kymcoforum.com/Smileys/default/cool.gif)
M8 bolts and spacers to attach the hitch frame to a cast aluminum bike frame like this one. He also said that using bolts through the frame would be better than using U-bolts. I was also thinking that as well. So I think that is the direction I will go. It would make it much more secure and easier to attach. I would only need a spacer on the forward attachment point and not at the rear attachment point right at where the hitch frame goes through the plastic. Of course drilling the holes would require that I remove the rear side panels but that's OK.
As it has been so far this is a project that will require doing a little bit, test fitting, going back and doing a little more, repeat. That includes any metal bending or welding that I have done... a little at a time when I have the time.
