I took the tubing with the V cuts to the welder on March 12 to have it bent and welded. He took a bit of time to clean up all the welds including the welds on the flat bar that were done earlier. He used his grinder to polish the tubing to clean it and give it a little bit of shine so the coating I put on will stick better. He also welded on the nut to the top end of the hanger bar since I won't be able to fit any wrench on the back side of that when I install it. This picture is the result of the tubing. I don't yet have the ends cut to length. The ends to the right will be cut off about 4-4.5 inches from the last bend so I'll have plenty of extra stainless steel square tubing left over. I also show the pattern for the angles I cut from some scrap aluminum sheet I had laying around so we'd have a guide while welding. A paper or cardboard pattern would burn if used while welding.
https://photos.app.goo.gl/7WmfkSoFQTFabtkQ7Those of you who do much welding know that any weld joint will shrink as it cools. We checked and checked and checked the alignment to the angle on the template I made to ensure it was right BEFORE the welding was done and also JUST after the initial tack weld was made. Later in the evening when I was home I was rechecking the 2 tubes and noted that the angles on one were off from the other one. So I checked on the template
again (finally) and found that both tubes angles were off by a few degrees. All angles were too sharp and needed to be opened up a few degrees. I calculated and determined that the lower angles on both tubes were within a half degree of each other but the upper angle bends were off by 3-4 degrees or more. So the next day I went back and the welder cut both tubes at the bend and we opened up the angles over compensating for shrinkage and drawing in the angle. This time we clamped each tube directly on the template with one leg offset by a few degrees. We did not clamp on tube to the other tube to line them up since that didn't work the first time. This time both tubes were exactly inline with each other and the last leg was 1 deg more than I originally wanted. Close enough.
After some thought I found that since the plate is angled back 1 deg that is easily corrected by the thickness of a single washer at the bottom bolts for the plate. So I'll likely put a washer between the hitch tube ends and the plate for the bottom bolts to bring the plate to true vertical OR put the washer between the plate and the receiver on the bottom pair of bolts for the same result.
Today I bolted both tubes on the bike, as tight as my fingers could get the nuts. I had cut off the end legs as long as they needed to be (4.25 inches from the top of the lower bend) and both tubes lined up perfectly. With the tubes on the bike the ends of the tubes were inline and level with the bike straight up. I clamped the end plate on the last leg to see if I needed to cut off any from the length and the plate was 1/8" wider than the outside of the tubes so I decided to leave it alone. 11-3/4" for the outside width from one tube to the other and the plate is 12" wide. I lined up the bottom of the plate flush with the bottom of the tubes and put a level on the plate. It is perfectly level. I estimated the height from the floor to be close to 1" lower than the previous owner of the trailer had the receiver on his Gold Wing. I marked and drilled the holes in the plate. 4 holes, 2 on each side, 1" from top and bottom and 7/8" in from the outer edge. Then I marked where to drill the holes for bolts in the lower leg of each tube.
While I have the tubes bolted on the bike I started working on the cross bar for the hanger. I am bending the cross bar to account for clearing the suspension travel of the tire. The rear fender has an angle that the tire will never reach and that is where the cross bar will arch into. That will put the cross bar about 3" down from the top bend in the tubes. I am heating the bend points on the cross bar with my Propane torch. It does get the steel red and easy to bend with a big pipe wrench I have but it does take a little time to heat it up. I'm not finished shaping the cross bar yet but will go back out later tonight to work on it some more... maybe.
Here is what the end plate looks like on the hitch frame. It is wide but that's OK with me. The perspective of the picture makes it look wider than it really is compared to the bike.
https://photos.app.goo.gl/sEMsyBHrmMmfhAac7After those photos I did drill the holes in the end plate to mount to the square tubes and marked the square tubes for drilling those.
Then we went on a short vacation (one week) to visit my son and his family in Lafayette.
I was back home a few days ago from visiting in Lafayette so back at this project. Doing daycare for our granddaughter today and tomorrow so not much time to work on the bike. But I did get a little done late afternoon. Connected the trailer harness wires and drilled the holes for the end plate in one of the square tubes. Hope to drill the other square tube tomorrow.
I did a lot of rethinking about the hanger bar. I am not able to bend the bolt plate that would sit on top of the bike end frame just under the seat hinge enough to clear the seat hinge as I was wanting to so I need to think of something else. I might be able to mount the top end of the hanger bar a little farther forward without going into the tail. Or maybe I won't need it at all. I am close enough to see how strong the hitch will be without it so will decide after a test pull of the trailer. That test pull will happen after I drill the other square tube, drill the hitch end plate for the Uni-Go receiver, and mount all the hitch frame parts to the bike. Then I can go for a ride with the trailer to see how it pulls.
Here is a picture of the wire mess behind the rear right side body of the bike. I will be tying the wire bundle to make it a lot neater before I close it all up. In the lower left of the photo can be seen the square 5 pin connector I added to make it easier to disconnect the trailer wire harness. I may yet rethink that as well since I am using mainly Posi-Tap connectors which are easy to disconnect wires from. I just happened to have that square connector in my electrical parts box.
https://photos.app.goo.gl/bR5Adidke8cY8qZm6
