Author Topic: [Solved]Starting issue  (Read 2361 times)
darkshvein
« on: December 15, 2023, 08:15:01 PM »
Good day.
My x500 won't to start.
I recharge battery, riding 1-2 days and problem appear again: While press starter button, Voltage drop lower than 12v, and scooter cannot start.
But with Bosch charger, battery have no problem  ???
Look like forum, this is stator error?
« Last Edit: December 27, 2023, 09:53:22 PM by darkshvein »
Re: Starting issue
« Reply #1 on: December 15, 2023, 09:23:53 PM »
As @CROSSBOLT would say, "oldy moldy story" of this XC 500.
This scoot (if 500i model) needs a very healthy battery to get alive. A weak or demaged batt will not fire your scoot up.
(pls see link)
https://www.kymcoforum.com/index.php?topic=33615.0
I changed from lead battery to LiFePo4 batteries on all my scoots and bikes, no probs since then to make them run.
Should this battery be a new, healthy one, then
- check whether enough voltage is put out from your regulator before you get to your stator
Proc: start motor, check with a multimeter voltage arriving at your battery at 4000 rpm (~14+VDC)
-less than that indicates  a faulty regulator on most cases...
Pls check this and come back for more.
« Last Edit: December 15, 2023, 09:31:40 PM by Ruffus »
darkshvein
Re: Starting issue
« Reply #2 on: December 17, 2023, 08:22:19 AM »
Yes, I plug voltage monitor into "cell phone socket", and while motor turned on show ~13v.
Re: Starting issue
« Reply #3 on: December 17, 2023, 08:50:10 PM »
Buy an inexpensive multimeter and read voltage at plus and minus battery terminals. At your cell phone socket you might have not the true values.
JJJoseph
  • Kymco Sento
Re: Starting issue
« Reply #4 on: December 19, 2023, 05:27:36 AM »
Definitely not a "stator error" - sounds like an old battery.
darkshvein
Re: Starting issue
« Reply #5 on: December 24, 2023, 04:12:29 PM »
lol, kghem. I stay battery at warm house and after 2 days it restore power and motorcycle start normally, in all conditions. Now I wait new AGM.
darkshvein
Re: [Solved]Starting issue
« Reply #6 on: December 27, 2023, 09:54:07 PM »
Solved - upgraded to AGM.
« Reply #7 on: December 28, 2023, 05:38:38 PM »
Congrats 👍👍🤗and a Happy New Year 🍾🥂
