Author Topic: Stock Air Filter Alternative  (Read 3552 times)
ozzyville
« on: December 21, 2010, 10:01:39 PM »
Hi, are there any alternatives for stock airfilter ?
Dr. Scooter
Re: Stock Air Filter Alternative
« Reply #1 on: December 22, 2010, 01:42:49 AM »
I adapted a k&n and did away with the stock airbox
2007 Kymco Xciting 500
Modding a scooter is a beatiful thing!
ozzyville
« Reply #2 on: December 22, 2010, 08:49:39 AM »
What is the part number ?
EFIALTIS
« Reply #3 on: December 22, 2010, 04:28:35 PM »
i modified the existed one with Malosi Sponge
Hoolander2
« Reply #4 on: December 22, 2010, 05:26:49 PM »
http://kymcoforum.com/index.php?topic=3347.msg37541#msg37541 Read down and find part # in this thread.
ozzyville
« Reply #5 on: December 22, 2010, 09:19:02 PM »
I saw the partn number but there is mentioned about a modification to use that filter because it is not shaped as stock filter.
Hoolander2
« Reply #6 on: December 23, 2010, 02:59:24 AM »
As far as I know there is no after market filter that is an exact fit replacement for these scooters.  Some owners replace the paper in their stock filter with foam.  Others do the modification like Arkie_Rider did.
ozzyville
« Reply #7 on: December 23, 2010, 05:58:18 AM »
Thanks for help
Alex
« Reply #8 on: December 25, 2010, 12:19:38 PM »
I  cut the old paper ( and boy is it thick paper) out of a stock filter and replaced it with a section of a K&N filter from  another vehicle which fit the Stock filter body. Cant remember which vehicle the K&N filter was supposed to fit . if you need this info I can back track and find it ..the replacement section has to be glued in with a polyurethane based glue which will bond to the OEM filter body
sissy mary
« Reply #9 on: January 31, 2012, 03:55:40 PM »
That DNA looks good, just like a K&N. Would we have to rejet to use this filter? I have a Leo Vinc on my 2007 X500 now, and it spit's a little when you back off on the throttle to idle speeds.  I know it's a little lean now. So I know I need to go up 1 main jet size, but would this new filter require that I go up 2 sizes?   :-*
Hoolander2
« Reply #10 on: February 01, 2012, 05:55:14 AM »
Good info, munks.  Thanks  ;)
jan.strydom
« Reply #11 on: February 01, 2012, 09:10:58 AM »
Yup, great info - will source one right away... thanks
guile
« Reply #12 on: February 20, 2012, 10:24:01 AM »
EFIALTIS, could you explain how you modified the exisiting one with foam?
If you cut out the paper, how did you manage to put foam in there without false air?
guile
« Reply #13 on: March 17, 2012, 01:01:53 PM »
Must have been made out of gold...
Too expensive for me!
sissy mary
« Reply #14 on: March 17, 2012, 01:26:56 PM »
Yes, but keep in mind that you will only need to clean the filter about every 50,000 miles or so if they are like the K&N filter's? And they last forever. Last filter you will ever buy. Also, I think the stock Kymco is about $40.00 bucks now? I just changed mine not long ago, but I am going to get a K&N style next time. And I think since I have a Leo Vinci exhaust I will need to go up a main jet by 1 or 2 sizes? :-*
