Author Topic: 2019 kymco uxv 700i engine light comes on intermittently  (Read 2983 times)
Uechikid
« on: January 16, 2024, 09:34:26 PM »
My UXV 700's engine light comes on and turns off for no apparent reason.  The oil is full and pumping, it has coolant and it happens when the engine is cold.  I read something about codes but I don't have any way of knowing how to find that out.
Any help would be greatly appreciated.
Re: 2019 kymco uxv 700i engine light comes on intermittently
« Reply #1 on: January 19, 2024, 12:12:21 PM »
Good morning - welcome to the forum!
Dealer no help?, or?
« Reply #2 on: January 19, 2024, 02:15:32 PM »
Try to:
-detach both battery cables for a few minutes (hold them together a couple of seconds)
-unplug/replug all sensor connectors
(cranksensor, TPS 2x, MAP -sensor, ECU,.....)
Try ECU  sync:
-ignition off
-throttle once full open and close
-ignition on
-for exact 8 seconds throttle full open
-throttle close
-ignition off
Jump start battery from a car, does it last ?
This 700 motors are known for failing CPS (CrankPositionSensor) and faulty Camshaft Position Sensors, both  going south at early kms.
« Last Edit: January 19, 2024, 07:26:58 PM by Ruffus »
Uechikid
« Reply #3 on: January 19, 2024, 05:05:17 PM »
I never found a dealer that was willing to offer advice or help to a diy-er except, bring it in, we’ll take a look.  And, short of renting a trailer I don’t have anyway to get it there.
« Reply #4 on: January 19, 2024, 05:45:58 PM »
idle speed?
Uechikid
« Reply #5 on: February 29, 2024, 05:49:33 AM »
Try to:
Try ECU  sync:
-ignition off
-ignition on
-throttle close
-ignition off
Sorry but, were you serious about all that.  I may not be an experienced mechanic but that sounds a little out there.
Again, I’m sorry.
« Reply #6 on: February 29, 2024, 09:45:42 AM »
Again, I’m sorry.
Yes, Ruffus is serious and a v experienced mechanic. He’s helped many on here.
Uechikid
« Reply #7 on: February 29, 2024, 04:08:13 PM »
Ok thanks.  I’ll print his response and see if I can figure this out.
« Reply #8 on: March 01, 2024, 07:30:53 AM »
Good plan. If you get stuck, post back on here with as much detail as you can and I’m sure someone more mechanically adept than me will help! They love a challenge!
