Author Topic: help starting UXV 500  (Read 468 times)
BHaning
« on: January 18, 2024, 08:32:07 PM »
I have a been loaned a UVX 500 to use on the farm.  It was running fine until last week.  I had it parked idling and had the lights on to work on some outdoor plumbing at night when it died.  I tried charging the battery and replaced the battery.  It has no power at all.   What should I check next?  Ben
Re: help starting UXV 500
« Reply #1 on: January 18, 2024, 09:30:43 PM »
Pls check the fuses,
then make sure all batt cables are properly fixed.
BHaning
« Reply #2 on: January 19, 2024, 07:10:42 PM »
I checked the fuses and tightened then battery cables.  Any other ideas?
« Reply #3 on: January 19, 2024, 10:40:02 PM »
Battery connections clean? No corrosion? Green on one and white on other = bad connection. Can be tighter than a gnat's butt stretched over a banjo and still not conduct.
I gather everything went off, right?
BHaning
« Reply #4 on: January 20, 2024, 01:00:01 AM »
All the battery connections are connected to their correct colors.  No power at all. I thought about getting all new fuses although they all look fine.
« Reply #5 on: January 20, 2024, 06:18:22 AM »
The colors I mentioned are relating to corrosion at the terminals. The hint was to disconnect the terminals at the battery, inspect for corrosion and reconnect..
Question: did everything just "turn off" all at once?
Question: have you inspected for loose connections?
« Reply #6 on: January 20, 2024, 09:48:28 AM »
I've had cancer of the wire harness on my V-Strom, could be at any connection, I use products from CAIG Labs for electrical cleaners & greases (conductive & non-conductive) great products ! https://caig.com/
« Reply #7 on: January 20, 2024, 11:29:30 AM »
Approach this issue logical:
-take a multimeter of testlamp
- battery has how many volts DC?
-ignition on
-killswitch on ON
-MM or testlamp on starter relay, current there?
In this way handle further.until you see NO CURRENT
-then scrutinize this surrounding for open connectors, broken cables, etc...
