Author Topic: idle adjustment  (Read 2201 times)
jasbos
idle adjustment
« on: January 22, 2024, 12:02:05 PM »
Hi how do I get to the idle adjustment do I remove the seat or is it near the air filter?
Re: idle adjustment
« Reply #1 on: January 22, 2024, 01:35:49 PM »
assuming your scoot has a carburetor, the idle adjustment will be a screw you turn that adjusts the throttle butterfly. It is found on your carb, under your seat / seat bucket.
jasbos
Re: idle adjustment
« Reply #2 on: January 22, 2024, 02:58:15 PM »
hi tks for the information I'll look were you said
Re: idle adjustment
« Reply #3 on: January 22, 2024, 04:06:23 PM »
follow your throttle cable to the side of your carb..you should see the adjustment screw there
