Author Topic: Like 200i Mirrors  (Read 502 times)
awluter
Like 200i Mirrors
« on: January 30, 2024, 04:32:06 PM »
Does anyone know where I can purchase the bolt/mount for the stock mirrors?  One of mine was bent/broken.  See photo below of the part I am trying to source.  Thanks!
Re: Like 200i Mirrors
« Reply #1 on: January 30, 2024, 06:47:11 PM »
@awluter welcome here!
Depends where you are located at.
Here in Europe I would look into EBAY or any other internet platform for a used mirror plus part.
Or I would take this part and try my luck at any motorcycle shop which sells asian/ japanese bikes.
It'a very common socket with an 8mm thread and should be available easily.
« Reply #2 on: February 01, 2024, 11:58:27 PM »
I'm assuming that the part in the photo is the undamaged mirror adapter, yes?
These LIKE mirrors have a smooth stem, no threads!
So, I suspect that this mirror-stem, locking fitting is going to be a tougher find. It works by pinching, compressing the adapter around the smooth mirror stem to lock the mirror in place - if remember correctly?
There are a million "mirror adapters" out there - but I saw none like this one as used by Kymco on the LIKE.
I found a pair of used mirrors on ebay. A new mirror with the fitting is @$48.
Maybe you could find this piece of hardware at a Fastenal store - or at least learn what they are called - so you can search for one?
Welcome to the forum and good luck!
