Author Topic: Tail Light Bulb Access  (Read 2475 times)
Dav
« on: February 19, 2024, 01:19:18 AM »
Sooo...my brake and tail light weren't working.
The manual says to remove the seat bucket, the seat, the rack, the bodywork etc etc. I tried that but you still can't reach the bulb.
I was sure a company like Kymco wouldn't make you go through all that just for a bulb so I took another look today and viola! Theres a wee inspection hatch on the wheel arch under where the pillion would sit. A couple of push pin coonnectors and the cover has a couple of tabs....easy peasy.
Re: Tail Light Bulb Access
« Reply #1 on: February 19, 2024, 01:33:24 PM »
that's refreshing to see! My S200 required full seat tub plastics removal for a simple rear bulb change.
« Reply #2 on: February 21, 2024, 10:41:22 AM »
Excellent post!
Yeah, the LIKE200i has the same plastic hatch....behind which are the brake, running and turn signal bulbs. Lay on back. Look up under rear fender.
« Reply #3 on: February 23, 2024, 03:16:36 PM »
Mental note, underlined in red, made of that!
JJJoseph
  • Kymco Sento
« Reply #4 on: February 25, 2024, 01:56:06 AM »
This alone sounds like a good reason to switch to an LED tail-light! I now realize why I've never had to change bulbs on my 15-yr old Kymco (all factory LED lights).
