Author Topic: Seat light not turning off  (Read 836 times)
Skello
« on: February 28, 2024, 08:46:54 AM »
Hi
My 300i 2011 has a seat light which is stuck on. I know I can disconnect it, but is there a part I can change to make it work properly?
Thanks
Re: Seat light not turning off
« Reply #1 on: February 28, 2024, 11:38:11 AM »
@Skello welcome here!
Yes, you can make it work properly again, by:
-taking out your METIN box
-watch closely RH from your seat-lock
-there is a small square switch which initiates your undertray light
-spray some WD 40 or similar in it
Works?
- if not, take this switch out, using a small blade from RH side to unlock
Pls give a feedback.
