Author Topic: 2003/2004 kymco mongoose 90  (Read 1638 times)
Lineman30
« on: March 17, 2024, 10:00:46 PM »
This was purchased new, and full engine rebuild 6 years ago or so. Currently has no spark doesn’t have a battery have been trying to kickstart, does this bike need a battery in order to get power to the cdi even when kickstarting? All research points towards this model having a dc cdi and the one in the atv is still the original from sept 2003. Thanks all!
Lineman30
Re: 2003/2004 kymco mongoose 90
« Reply #1 on: March 19, 2024, 02:31:03 AM »
Fourwheeler now has spark, however it will only run with the auto choke removed and finger over the hole. I cannot seem to find a replacement carb for this model, I’ve cleaned the carb 4 times including letting it soak overnight. Carb is a keihin with 42mm mounting.
Bratman2
« Reply #2 on: March 19, 2024, 05:11:06 PM »
Well, I went out there and disconnected the battery on our 90 just to see if it would crank with the kick start. It did! Guess you know that now. Have you checked Ebay for the carb?
Ebay has two! A brand new one and a used one off a 2010 model! I think your mm mounting hole may be off some. When I searched Keihin 42mm it was listing carbs for 500cc machines.
« Last Edit: March 19, 2024, 05:16:35 PM by Bratman2 »
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
