Good morning guys....
Is anybody still messing with the ags around here?
IF so, have you jetted for the winter? What size are you running now?
I happened to install a multivar with 5.7g rollers and LOST 5-7 mph.. Of course i have a hand done "100"-"101"? jet in at the moment... Thanks for ANY input guys
As a general rule its a 80 jet stock, 82 jet deslrestricted, and 88 for an open air filter but im sure you prob know that most scoots vary slightly?
I dont swap my jets for winter here in Scotland, maybe i should?. I just run the 82 all yr on mine?
Comes out ok on plug for me no leaness or richness, tho its always a little slower in the cold or wet, 3-5mph sometimes.
Had a similair issue a while back where i couldnt get the plug right, was way too rich then added more air in and got better but still had a sooty plug a bit. Found out eventually i had slighlty too much engine oil in cos i filled it on a slope, drained a little off and refitted the 82 jet put back on my stock air box and it was perfect again.
