Author Topic: Venting the Kymco locking gas cap  (Read 1605 times)
« on: April 29, 2024, 11:16:24 PM »
Solved my problem with sudden death and slowly  dying scooter engines. Modern setups have a vacuum operated vent valve that sticks shut.
Re: Venting the Kymco locking gas cap
« Reply #1 on: April 29, 2024, 11:18:56 PM »
Remove these two screws and have a good grip on this cover and the two catches because they are spring loaded!
« Reply #2 on: April 29, 2024, 11:23:52 PM »
Diassemble the parts being very careful the sequence. Place them in a similar, organized fashion for reassembly.
« Reply #3 on: April 29, 2024, 11:25:48 PM »
White arrow points to where vent hole is to be drilled.
« Reply #4 on: April 29, 2024, 11:27:07 PM »
White arrow points to the drilled hole.
« Reply #5 on: April 29, 2024, 11:31:46 PM »
Put it back together!
The key goes into the slot lined up with tiny triangle at the top of the black cover held on with three tiny screws. The key opens the cap with a quarter turn to the right. Make sure this action works like this after you reassemble!
I'm getting old. Any one have an extra black spring? It's in the shop somewhere...
« Last Edit: April 29, 2024, 11:33:42 PM by CROSSBOLT »
« Reply #6 on: April 30, 2024, 12:38:40 PM »
Wow, nice write up! And those little springs will run away any chance they get
« Reply #7 on: April 30, 2024, 02:46:30 PM »
Yeah I've got plenty Karl, behind the garden equipment in my garage somewhere!
« Reply #8 on: April 30, 2024, 03:58:10 PM »
Nice work Karl!
I think it was you who had me drilling a hole in my LIKE's gas cap years ago - when it was doing that imitation of a bucking bronco. (as the TPS failed)
Couldn't hurt!
Man - I learned more about taking my LIKE apart and putting it back together in those few weeks of fairly new ownership when that TPS went south!! Still have some "nothing the matter with these orig. parts" in my tool drawers as the forum recommendations rolled in! ! (fuel pump, coil, plug cap, plugs, plug wire, injector, etc.)
Then you loaned me your KYMCO diag. tool! And we got it solved.
« Reply #9 on: April 30, 2024, 05:13:09 PM »
There was a request for this from an owner of a 2011 DT300i. I knew it would be quicker to do the photos than to find the original post.
Yes, Neil, I have the same spot in my shop! Har, har!
Stig, that was the eyeopener to how disinterested dealers and their techs were in learning their product.
Almondog
« Reply #10 on: May 29, 2024, 02:23:22 PM »
I put a non locking cap on my super 8 150x  from a honda nc700x. Fits perfectly.
« Reply #11 on: July 02, 2024, 09:19:56 PM »
FOUND THE SPRING! It is back in the gas cap!
« Reply #12 on: July 02, 2024, 10:31:44 PM »
Karl lost that spring in 1987. It was a Tuesday.
This man never gives up!
« Reply #13 on: July 03, 2024, 08:52:06 AM »
Karl, you legend!
« Reply #14 on: July 03, 2024, 12:16:14 PM »
Aw, shucks, guys!
