Author Topic: Please help with my 2012 Kymco Like 50 2T  (Read 2174 times)
jabl7425
« on: May 01, 2024, 06:45:08 PM »
Hi everyone! Hopefully someone can help and/or have insight on this.
So I just took out my Kymco and right away I felt something off. I would be riding and heading towards a stop sign I would feel it slowing down without touching the brakes. When I got home I put it up on a stand and noticed the front wheel was not spinning freely (lots of resistance) unlike the back tire.
  I figured it has something to do with the front brakes, but I want to try everything before actually dismantling the whole front wheel.
 Please anys suggestions/thoughts. Thank you in advance!!
245luigi
  • Boston, MA
Re: Please help with my 2012 Kymco Like 50 2T
« Reply #1 on: June 03, 2024, 05:48:18 PM »
Remove the brake and try the same test
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
« Reply #2 on: June 05, 2024, 03:13:14 PM »
Check brake fluid level in the reservoir window!
Look good?....then ...
Scrub the front disc with a rough green plastic dish washing pad.
If that doesn't free it, it is likely a contaminated brake pad.
Spray brake cleaner on disc - spin wheel to get the brake cleaner to the pad surface.
Report back.
