Author Topic: Bogs down at about 35 mph  (Read 2607 times)
CBonafide
« on: May 06, 2024, 08:43:29 PM »
Hello,
Recently my agility 125 dropped out while riding. It starts, idles fine, but when I give it a turn of the throttle it bogs down and chokes. I thought it might be the CDI but I had a new spare and tried it and nothing changed. It runs smooth if I feather it up to 30-35 mph then it bogs down. I cannot detect any type of vacuum leak either. Gas is clean, got a new plug wire, new CDI, anybody got any idea?
Re: Bogs down at about 35 mph
« Reply #1 on: May 07, 2024, 08:54:54 AM »
-open fuel tap
-you might look into your carb whether all passages are clear
-check vacuum fuel pump and hoses for demage and functionality/tight fit
-Inspect this diaphragm in your carb for tiny holes in it
-take the airfilter out to see if clogged
« Last Edit: May 07, 2024, 08:56:31 AM by Ruffus »
JJJoseph
  • Kymco Sento
« Reply #2 on: May 08, 2024, 09:18:41 AM »
Hello,
Don't know if this is useful, but an old stator will cause your motor to repeatedly "bog down" at constant cruise speed. Just slightly, but enough to be annoying. You'll need a flywheel puller to get at the stator to change it. Takes about an hour to do the change.
« Last Edit: May 08, 2024, 09:24:06 AM by JJJoseph »
