Author Topic: Having trouble accelerating from a full stop.  (Read 2674 times)
devrongrimm
« on: May 15, 2024, 01:48:28 AM »
Has anyone experienced this kind of problem with your unit?
When coming from a full stop and then you start to run your scooter it is having a hard time in accelerating.
From 0 - 20 or sometimes 30 kph it so slow, like something pulling it back. But once you're moving about 40 kph there's no problem from reaching 150+ kph.
It is just from the full stop acceleration.
I hope someone could share there experience with me if ever they've encountered the same problem.
Re: Having trouble accelerating from a full stop.
« Reply #1 on: May 15, 2024, 11:20:12 AM »
Miles on your scooter?
Miles since last CVT servicing?
« Reply #2 on: May 15, 2024, 07:38:28 PM »
@devrongrimm welcome here!
First measures in this case should be:
-scoot on mainstand
-brakes pulled and released (stationary brake too)
-try to move rearwheel by hand
-rotates freely, YES/NO
-if NO your rear brakecylinder/disc or hand brake
needs to be revised
-if YES, take off all CVT covers (3) and check whether all moves there properly
-rear alu cover with inserted support bearing stucks sometimes and is hard to remove.
devrongrimm
« Reply #3 on: May 18, 2024, 11:46:01 AM »
Haven't done any CVT servicing yet. But the miles is almost at 10k so it is scheduled for PMS.  I would have it checked there since you mention it. I'll update here if the problem has gets fixed.
devrongrimm
« Reply #4 on: May 18, 2024, 11:47:22 AM »
-scoot on mainstand
needs to be revised
Okay, I'll do this and check the things you mentioned. I'll update once I've checked it.
