Author Topic: discussion about Dr Pulley sliders  (Read 707 times)
« on: July 04, 2024, 05:32:21 PM »
Below is a quote from https://www.buggypartsnw.com/ (I've always purchased my Dr P sliders from these folks)
Dr. Pulley Slider Weights are a different style of roller
The unique shape of the Dr Pulley weights offer a variety of benefits:
- Sliders engage up to 20% faster than traditional round rollers.
- Due to their form-fitting shape to the interior dimensions of the variator, they allow you to engage in higher gear ratios, even when using lighter than stock weights.
- Dr Pulley Sliders last longer with much less wear than round rollers because they slide rather than roll (hence the name!). Round rollers develop flat spots over time that will contribute to rough accleration and deceleration, as well as reduced overall performance.
Rollers and sliders should be inspected annually (at minimum) for wear. If flat spots or obvious wear is detected, they should be replaced. This is one advantage of sliders, as they already have flat sides and are not affected by this wear as much as rollers.
Choosing the Dr Pulley Slider's weight:
- Lighter weights (7-9g) will give a lot more climbing power at the cost of some top end speed. Cruising speed RPMs will likely increase as well.
- Middle range (10-12g) weights will give improved low end power, climbing, and acceleration versus stock weights. Top speed should be similar to stock weights, and RPMs will be similar to the stock weights
- Heavier weights (13-16g) retain (or slightly improve) existing top speed with the possible expense of climbing ability - but are great for reducing top speed RPMs for better gas mileage.
Scooter Owners: Most popular choices (and why!)
- 11g:  Great all-around weight for a mix of hills and flat road riding. Our most popular weight for scooter owners. Works best with the stock main spring. Aftermarket CDI worth considering.
- 12g: For mostly flat ground riding with occasional hills. Some low end gain, excellet top speed retention. Works best with the stock or yellow main spring. Aftermarket CDI worth considering.
- 13g: Great weight for commuting and those who spend a lot of time at cruising speeds. Slightly better low end compared to stock weights. Possible top speed gain and lowered top speed RPMs.  Works best with the stock or yellow main spring. Aftermarket CDI worth considering.
Note: Using Slider weights that are at the lower end of the weight scale can be too light to overcome the main torque spring tension (expecially wih the stronger performance main torque springs) before hitting the RPM limiter in the stock CDI (sparl ignition unit).  This can result in less top speed. You can typically get around this using a performance CDI unti with a higher RPM ceiling.
Click here to learn how to install this product!
Important Note: When installing Dr Pulley Slider Weights, refer to this article for specific instructions on the proper orientation for slider weights.
For Buggy Owners, this product fits all 150cc buggies based around the GY6 125cc and 150cc motors.
For Scooter owners, this product will work with the following brands (and more). Stock roller weight for a each vehicle is listed in Blue (where available). Stock roller weight is meant to assist you in choosing the weight of your Dr Pulley Sliders. Most people choose a weight 10-15% lighter than the stock round roller weights.
Buddy: 125, 150
Honda: Bali 125/150, Pantheon 125 (14g)
Kymco: Agility 4T 125 (2006) (13.4g), Agility 4T EU3 125 (06-08) (13.4g), Agility R16 125 (2009) (13.4g), Agility RS 125 (2009) (13.4g), Agility 200 (13.4g), Downtown 125L (2009) (13g), Heroism 125 (95-97), K-XCT 125 (13g), Like 125 (2009) (13.5g), Movie 125 (99-00), Movie 125 EU3 (06-07), Movie S125i (12g), Movie XL 125 (2001), Movie XL EU2 125 (03-04), People 125 (99=00) (12.8g), People EU2 125 (2003) (12.8g), People EU3 125 (07-08) (12.8g), People S 125 (2005) (12.8g), People S DD EU3 125 (07-08), Super 8 125 (08-09), Vivio 125 (2000), Agility R16 150 (08-09), Heroism 150 (95-97), Movie 150 EU3 (06-07), Movie XL 150 (2001), Movie XL EU2 150 (03-04), People 150 (99-00, 03), Vivio 150 (2000), Like 200i (2009), People S 200 (2005), People S 200i (2007), SB 125 (13g), MXU 50 (8g)
Malaguti: CIAK 125 (00-01, CIAK Master 125 (2004, 2006), CIAK RST 125 (2003), CIAK 150 (00-02), CIAK Master 150 (2004), CIAK RST 150 (2003), CIAK Master 200 (2006)
PGO: G MAX 125/150 (14g), T-REX 125
SYM: Attila/Euro MX, Joymax 125~180, RV 150~180, VS125 (10g), GTS 125 EVO (10.5g)
TGB: Motion 125 (10g), Bellavita 125 (10.5g)
Taishan: TS 125
Slider weight size 18x14. This product comes with six slider weights in the package.
Don't see the weight you are looking for? Email us and we can special order weights from Dr Pulley!
mrmike
  • Syuracuse, NY
Re: discussion about Dr Pulley sliders
« Reply #1 on: July 04, 2024, 10:06:05 PM »
   Just a observation! I have a '23 People S 150i ABS scooter. I bought it in March, and it now has 700 miles on it. I just took my variator apart to install Dr Pulley sliders. The stock rollers in my People were 10gr. With only 700 miles and they were already developing flat spots. I'm waiting for my 9gr Dr Pulley sliders to get here from Buggypartsnw.com. With priority mail they should get to me in 1 to 3 days. I recommend taking your scooter apart to determine the factory weight before you order Dr Pulleys. I personally have installed lighter Dr Pulleys in my last 3 scooters. I was very happy with the results. I recommend them for longevity and better performance.
« Reply #2 on: July 05, 2024, 12:55:51 AM »
My take on the wear on stock roller weights is not nearly so dire! Sure, they show some wear after even a couple hundred miles.
I was told years ago that rollers are made of something other than metal so that they wear - and not variator parts. Rollers are scheduled for a change at intervals of several thousands of miles. And they are always found to have signs of wear, flat spots, buffed dark areas, etc. but,....but darn few of us notice any difference in the performance of our CVT as these rollers reach the end of their service life. Service schedules seem to give very conservative intervals for service.
At least - that has been my experience with a Honda, Piaggio, Suzuki and Kymco scooter. Others may have a different take on the subject.
I've learned to sweat the proper positioning of a Dr P slider when installing them - otherwise I forget my weights until next service time.
Just say'in...
mrmike
  • Syuracuse, NY
« Reply #3 on: July 23, 2024, 09:04:55 PM »
   UPDATE: I discovered my postage scale was broken. In reality my People S 150i had 13gr rollers from
                the factory. I replaced them with 11 1/2gr sliders from Dr. Pulley.
