Author Topic: UXV 500I Boggs when throttle applied, wont go over 6 MPH or 3500 RPM  (Read 3907 times)
J.Carter
  Hi guy's,  New user here & Thanks for having me as well!  I work on small engines occasionally & even get lucky sometimes on fixing them lol
Ok a neighbor bought a UXV 500I (Fuel Injected no carb) 2012 model year as far as I can tell. 3350 miles on it, 893 hours.  Its was non running for at least a year & kinda rough shape but not totally scrap worthy.
Got it to the yard, & started trouble shooting the vehicle for him.  Previous owner stated he had changed the fuel pump (Ne did not), ignition coil, & plug.  No joy there so he sold it.  He had removed the exhaust & also sold the front bumper w/ winch.   I wondered it it was a clogged exhaust issue being he removed it.
I drained the tank of old fuel & was able to jump it & finally get it started but it ran like pure garbage. Got it warm enough to do an oil & filter change at the least. Now the oil has been changed twice just for good measure.    Figured the valves needed an adjustment so I removed the cover & they were tight.  The intake cam is a bit rough like it was soft & or  starved for oil at some point - that's a bad sign I know.  Set the lash at 0.004 on both TDC.  That helped some but not much. tried setting them just a bit more in either direction to see the the difference.  It did help with cranking but I went back to 0.004 as that seems to be recommended.   Tried the exhaust both on & off the thing - no real difference
Its very hard to start sometimes & sometimes not so bad - the starter is loud but functional.
Fuel pump was the original so I got him to order a replacement knockoff  for a MULE & worked it into the tank as you can find on youtube.   That helped.   The coil was actually changed - he didn't embellish that part.  The plug sometimes comes out dark & really Soot covered.  Running rich & the stock plug sometimes loses fire & I use a smaller plug from my china 4 wheeler & it runs fine  go figure.
   Put a new battery in it & that really helped with the two codes - they are gone now.  it was showing two codes  to do with Charging & I forget what else but I got them cleared up.    The check engine light is on at startup still.  Goes away once started.
     The switch is a bit worn but functional, the starter is loud & sometimes takes a few seconds to fire the vehicle up.    It idles well enough, climbs hills etc in low or high but will not go above 6 MPH in High on flat ground. It wont go over 3500 RPM either.  sometimes it will do 11MPH tops downhill.  It Drinks fuel like nothing Ive ever seen so that leads me to think its a TPS issue or something similar.  Seems like something is holding it back - tried the air filter & cover both on & off  no real diff.
I think that's all the issues,  Sorry for the jumble here & any ideas before I start buying sensors etc?
« Last Edit: July 08, 2024, 12:06:18 AM by J.Carter »
Re: UXV 500I Boggs when throttle applied, wont go over 6 MPH
« Reply #1 on: July 06, 2024, 01:13:56 PM »
Welcome to the forum!
I know squat about UXV's so I'll stay out of this - help should be along ....
Good luck
J.Carter
« Reply #2 on: July 06, 2024, 01:29:01 PM »
Good luck
Thank you Sir, I understand its a long shot & I'm probably forgetting a lot of info that needs to be said also but it's worth a shot to see if someone out there has any fresh ideas on the strange issue here.        Its something small im sure, I pulled the belt cover off & it looks good for its age so thats another possible problem crossed off the list.
  I'll keep at it & maybe get some luck
Bratman2
« Reply #3 on: July 07, 2024, 01:48:26 PM »
Probably not your problem being it is drinking fuel, but I will throw this out there just in case. My 19 UVX 700 will not go over 7-8 mph unless my driver's seat belt is fastened. Could it be a bad switch in the seat belt? Are you are using the belt?
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
J.Carter
« Reply #4 on: July 07, 2024, 01:56:19 PM »
I had read about that I don't see any sensors going to this one Seat belt wise but I'll give it a try.
Edit, this earlier model doesn't have that feature,  I appreciate the try at it though sir!!
I did remove all the sensors & clean them, no luck there either.  Just seems something small is holding it back from its full potential...
« Last Edit: July 07, 2024, 02:38:49 PM by J.Carter »
« Reply #5 on: July 07, 2024, 11:48:02 PM »
Gobbling fuel may be injector pattern is so crappy that it is solid stream instead of fine spray. You mat want to observe spray pattern during start sequence. Should be a fine mist. Any streaming  send the injector to a shop for check and clean/repair.
Try Injector Master in Portland, OR...25 bucks and 24 hour turn around if no reliable shops in your area.
J.Carter
« Reply #6 on: July 07, 2024, 11:56:28 PM »
I did pull the injector, lightly cleaned & it blasts out a fine mist as you'd expect.  I'll recheck anyway just to be dead sure.  This is driving me nuts LOL.
J.Carter
« Reply #7 on: July 31, 2024, 02:08:19 PM »
  I ordered a new belt, maybe that will help as this one is at about the service minimum (its 1.25").
Ill post tomorrow when it comes in & I figure out how to remove the drives with the special tools.
I'll also inspect the clutch & drives for common worn parts (rollers, springs etc).
 Wish me luck...
J.Carter
« Reply #8 on: August 02, 2024, 10:21:11 AM »
  Well I got the new belt along with brake pads yesterday.
Picked up a G-Force belt & installed it along with an inspection of the drives etc.  Everything looks good, one slightly cracked roller but they all measure well within spec.  No real change, but it does feel a bit stronger uphill.      Its gotta be electrical or the wear to the intake cam lobe is all I have left to go on.
    Back to the drawing board I guess.
J.Carter
« Reply #9 on: August 11, 2024, 10:23:19 AM »
  Alright, for anyone in the future having a similar problem here's my findings.
I tried the new G-Force belt, it only helped via the placebo effect. Glad to have a new one on nonetheless. Cleaned & inspected both drives, they were dirty & so were their ventilation system ( the plastic tube).  The rollers were decent condition, only one had a crack in the side. Otherwise they all were still above minimum spec so I haven't replaced them yet.
  I ordered a new intake camshaft & got it yesterday.  Installed it & set the lash to .004 IN & EX. polished the rocker also.
    That was the ticket, she runs fine now.     Will report back if any issues arise.
Re: UXV 500I Boggs when throttle applied, wont go over 6 MPH or 3500 RPM
« Reply #10 on: August 11, 2024, 01:26:40 PM »
Cam bad or out of time? Both?
J.Carter
« Reply #11 on: August 11, 2024, 02:00:06 PM »
  Good question sir, the Cam lobe was almost nonexistent on the intake camshaft.  I had noticed it showed some ware when the machine first got into my hands but figured I'd tackle all the electrical problems/codes etc  first.    I was honestly just avoiding a big problem & should have tackled it first off but wasn't sure the machine would survive me lol.     The original owner was hard on this thing & it shows but she is looking & running much better now.
