Author Topic: Startar inte  (Read 7778 times)
Viggo
Startar inte
« on: July 27, 2024, 09:09:39 AM »
Hej.
Har en Kymco Vitality 50 2takt.
Får ingen gnista på stiftet. Byt cdi box...byt tändstift..byt tändspole...tändhat och kabel.
Kontrollerat kablarna...
Undrar samtidigt vad detta är på bilden
« Last Edit: July 27, 2024, 09:15:37 AM by Viggo »
Re: Startar inte
« Reply #1 on: July 27, 2024, 01:47:51 PM »
Hej.
Hello.
I have a Kymco Vitality 50 2-stroke.
I don't get any spark on the pin. Replace cdi box... Replace spark plugs. Replace ignition coil... Ignition cap and cable.
Checked the cables...
At the same time I wonder what this is in the picture
[Stig]
Scootsuper9
Re: Startar inte
« Reply #2 on: September 20, 2024, 06:14:53 PM »
That is the starter relay.
I am facing the same issue.
Confirm 12V DC to your CDI box. To do this, disconnect plugs from CDI. Turn key and killswitch to on. Put one volt meter probe on the battery negative terminal. Put the other probe into the connector on the black wire that has a blue stripe. Let me know what you have for DC voltage and get back to me.
