Author Topic: General maintenance and care  (Read 403 times)
micahneedham12
« on: August 04, 2024, 08:14:26 PM »
I have a 2011 Kymco like 200i, i got it at 2,200 miles and its about to be at 4,000. The only thing ive done maintenance wise once it was running is change the oil every 500 miles and the spark plug when it used to start rough.
Are there any parts, fluids, etc that i need to check or change?
I love this bike and want to make it last as long as possible
Re: General maintenance and care
« Reply #1 on: August 04, 2024, 10:59:26 PM »
brake fluid, for sure...rear end oil...check air filter...check date codes on tires as you may well be riding on original, 13 year old tires.  I'd also pull my calipers to clean them and lube up the slide pins. All easy stuff to do...
