Author Topic: Retrofitting winkers/ blinkers into oem light housing.  (Read 2180 times)
TXSUPER8
« on: August 15, 2024, 08:34:17 PM »
so im in the process of retrofitting the turn signals into the acutal oem light spots.. already did the headset blinkers . and the back all i need to figure out is which is positive and negative on the back turn signals . there is 1 set of wires green and orange and the other set is blue and green. on the bike would that mean green is the ground and the colors are positives or opposite.
TXSUPER8
Re: Retrofitting winkers/ blinkers into oem light housing.
« Reply #1 on: August 16, 2024, 12:02:30 AM »
never mind ! i got it all figured out used a multimeter .green wire is positive for all those wondering and or if you do the swap . its actually super simple all you need to do is drill out the holes i used a small drill bit then this guy https://www.harborfreight.com/power-tools/drill-driver-bits/step-drill-bits/2-piece-titanium-nitride-coated-high-speed-steel-step-drills-96275.htmlto make it the perfect size then go order these>  https://www.amazon.com/dp/B07F649C6K?psc=1&ref=ppx_yo2ov_dt_b_product_details then what i did was left the oem kymco male bullet connectors. cut them in the middle then soldered them together along with used marine wire shrink wrap ( it contains glue that when the wire shrink wrap shrinks down the glue seals everything .) anchor brand shrink wrap. the oem bulbs fit perfect everything works as it should looks cleaner imo without all the bs hanging down.
