Author Topic: It is time...  (Read 1540 times)
monkeybongos
  • Tampa, Fl
Re: It is time...
« Reply #15 on: August 26, 2024, 12:03:58 PM »
Just seeing the thread title was sad, knew what it meant.
Can’t say anything better than what’s already been said, except to add losing a mentor always leaves a void.  Even if some of the time I had no idea what you were talking about, due to your advanced mechanical knowledge.
If weight of your bikes is the problem, an e-bike might be a solution. But if your balance is suspect, then probably not, as you’d be higher up (further to fall) on skinnier tires.
2016 Wolf V-50 (sold)
Re: It is time...
« Reply #16 on: August 26, 2024, 06:22:52 PM »
Re: It is time...
« Reply #17 on: August 26, 2024, 06:51:59 PM »
Har, har! You got me there! This is more my speed these days:
https://www.facebook.com/share/r/baVXy4tpnLieTCYc/?mibextid=D5vuiz
I'm registered for the street here in NH, my tip over was due to fat feet, I was being guided in reverse to get within chain reach of a log I wanted to drag out, when my friend said stop, I stabbed the gas instead of the brake, and climbed the 3 ft high boulder hiding on the far side of my buggy
