Author Topic: Speed sensor lying  (Read 3747 times)
darkshvein
Speed sensor lying
« on: September 01, 2024, 04:54:21 PM »
Hello. How to fix speed sensor errors range? Maybe clean? It have tune "buttons" ?
Earlier it lie up to 20 kmh. now error value increased to 30-40 kmh.
// still xciting 500i r
Re: Speed sensor lying
« Reply #1 on: September 01, 2024, 05:34:31 PM »
@darkshvein, a common issue at this maxis from Kymco.
  Pls try:
- clean the speed sensor and rotor. take it off your wheel (sensor only)
-use alcohol or fine fuel for it
-mount it again with a distance 0.8 mm between  sensor and this  "rotor"
-have a test ride
-improved Y/N
-if NO ,change the distance with thin (alu foil) shims either to wider or more narrow
-Y/N
-take a multimeter and measure resistance
IF after several different "distances" your speedo does not get more accuracy, forget further efforts and live with it. An electronic smurf causes that in our scoots.
« Last Edit: September 01, 2024, 06:17:07 PM by Ruffus »
darkshvein
« Reply #2 on: September 03, 2024, 07:52:56 PM »
Oh right, distance.
darkshvein
« Reply #3 on: November 05, 2024, 11:33:01 AM »
Solved with extra one thin washer.
For second time))
first attempt maybe was wrong position. I set washer again and speed show correct value!
