Author Topic: Kycmo 400i problems  (Read 552 times)
fullt1wst
Kycmo 400i problems
« on: September 05, 2024, 09:34:27 AM »
Hello,
I bought a kymco 400i 2019  with 50,000KM  on it.
I am having  the  following problems if you can   guide me  i would appreciate it.
* sometime it turn off after  2  seconds of letting the throttle off.
* on traffic lights  when i start accelerating sometime it turns off.
* high vibrations at low RPM and also when idleing.
* Check engine light ON
* Poor acceleration.
* hasitation  when i start accelerating,
What's i did  so  far:
* replaced Spark plugs
* replaced  the Belt and  the  clutch assemly
* cleaned the injection
* cleaned the throttle body
OBD  check  showed throttle body sensor mulfunction.
i feel that this is more of an AIR issue
Should i replace the Throttle body sensor or it's not connected to the  symptoms i am having.
Thank  you in advance
Appreciate  any help.
Re: Kycmo 400i problems
« Reply #1 on: September 05, 2024, 04:01:41 PM »
@fullt1wst welcome here,
..most probably not related to other issues...
since I had lately a similar issue it might be worth to check your fuel supply.
-measure the fuelpumps pressure with a simple manometer or somewhere in a shop.
Needs appr. 3 bar to function properly within our injection system.
-do a TPS reset
-do failure code reset (ignore #3 or do it with an diagtool)
Maybe att link gives you some support.
https://www.kymcoforum.com/index.php?topic=34331.0
« Last Edit: September 05, 2024, 07:56:14 PM by Ruffus »
