Author Topic: Possible battery ground?  (Read 1626 times)
b dippin
« on: September 16, 2024, 09:34:57 PM »
Have a 2012 kymco agility 125 and did a gy6 motor swap 8 years ago. Just starting to finish this motor swap again and trying to find out where this wire attaches. Its routed with the main wire harness towards the engine. I think it's the main ground wire but not sure.. pics attached
« Last Edit: September 16, 2024, 10:58:32 PM by b dippin »
b dippin
Re: Possible battery ground?
« Reply #1 on: September 17, 2024, 03:37:04 AM »
I got it... was the main ground and ran to a starter bolt. I see 50cc mopeds run to valve cover bolts but it appears by the way the wire loom was run it was probably the starter bolts over valve cover bolts... let me know if I'm wrong on this..
« Last Edit: September 17, 2024, 08:16:25 AM by b dippin »
« Reply #2 on: September 17, 2024, 12:16:17 PM »
Yes its the main ground and is to be bolted to the motorbloc close to the startermotor with a 6mm screw.
Pls see link
https://www.kymcoforum.com/index.php?topic=31637.msg221509#msg221509
« Last Edit: September 17, 2024, 12:17:56 PM by Ruffus »
b dippin
« Reply #3 on: September 17, 2024, 01:01:02 PM »
Pls see link
Thank you for the confirmation!!!!
