Author Topic: Recommend tire press monitor caps??  (Read 668 times)
« on: September 18, 2024, 04:08:40 PM »
Anyone able to recommend a certain brand of tire pressure monitoring valve stem caps?
If these things are reliable and trouble free - I think I'd like to try them on my scooters.
Crawling around on the floor, finding angles that work with my air gauges.....is not my favorite thing🙂
Thank you!
Re: Recommend tire press monitor caps??
« Reply #1 on: September 22, 2024, 03:31:51 PM »
that's an issue with 10 & 12 inch wheels, the 14"s on my AK550 are more effort bending over than the 17"s on my K-Pipe. I find the wheel with the stem in the 4 o'clock position is easiest to check & air up, I have 90° air chucks
« Reply #2 on: September 22, 2024, 06:40:41 PM »
tireminder.com looks promising, although I couldn't find pricing for their motorcycle system. They appear to be big in motorhome and trailer tire  monitoring. 2 larger caps that screw on your stem that transmit tire pressure to a phone app. You can get alerts if they fall below a certain threshold.
Amazon is full of cheapies that are just caps preset to between 32-40 psi. They will go from green to yellow to red as pressure drops.
I was laughing at myself the other day...checking tire pressure on Nighthawk, 32 psi is target, both were at 31.5. It took everything I had to not grab the pump and add the additional .5 lb of air! (I did the next time I rode as they were both down a full 1 pound, unacceptable!)  8)
« Reply #3 on: September 23, 2024, 07:43:03 AM »
Ha! There’s your OCD kicking in right there Hawk!  🤣
