Author Topic: USA turn signals - how to wire to factory signals - Like 150i abs  (Read 1293 times)
Hbfoxjr
« on: September 26, 2024, 03:37:56 PM »
I’d like to add the global integrated turn signals to my add on USA turn signals.   Is that easy and how?
Re: USA turn signals - how to wire to factory signals - Like 150i abs
« Reply #1 on: September 26, 2024, 06:32:44 PM »
a lot will depend on how your 'dummy' signals are currently set up. On my S200 the 'dummy' signals were not wired. The global indicator used in the rest of the world came with built in led bulbs in the housing so I sourced a pair of slightly used indicators from Ebay UK.  You can then unhook and uninstall your US spec indicators and run the wires to your newly installed indicators.
If, however, your indicators are merely in need of a bulb, you can see if they are wired or if wiring is in there but not hooked up.
attaching a pic of the indicator I purchased, with already installed leds and wiring.
« Reply #2 on: September 26, 2024, 11:53:50 PM »
You want to connect the Euro's AND keep the USA turn pods, is this correct?
« Reply #3 on: September 28, 2024, 05:54:27 PM »
do you have any more info for us? Are you still planning on this mod?
mrmike
  • Syuracuse, NY
« Reply #4 on: September 28, 2024, 06:47:21 PM »
Ordering the European lights and wiring them in is the easy part. Getting the plastics apart to do it is a little harder. I modified the lights on my previous 3 Kymco scooters but it was a project. The jury is still out on doing my '23 People S 150.
