''Thanks for the response. No I didnt change the jet,but when I do,which size jet should I put in with a freeflow air filter? And also will I have to make any carb adjustments and with minimal mechanical ability will I be able to install the jet and freeflow filter myself? Thank you again Dale''
I had to adjust my carb recently for the cold weather and it was a matter of varying the ratio of air to fuel. The winter air is denser therefore I need less of it to get the right air to fuel mixture. On the outside of (most) carbs there are two screws, one called the idle adjust and the other is the pilot screw, which is used for raising/lowering the amount of air getting to the mixture inside the carb. On my super 9, I located the idle screw by warming up the engine and turning one of the screws a quarter to half turn (out). When the idle rpm went up I knew that was the idle screw (but I already knew that because of the manual). Now , to the pilot screw. The pilot screw as explained to me works in one of two ways. It is either turned in or out to cut off airflow. My pilot screw is turned in to cut off airflow, thereby making it richer (more fuel, less air). I have heard this is the usual set-up but apparently some carbs are designed differently. You are doing this to adjust the air to fuel mixture. The pilot jet always lets in the same amount of fuel, based on the diameter of the hole in the middle of it. That is why when you change jet diameter you need to change the amount of air coming in, done by adjusting the pilot screw. When you start with these adjustments make sure you document it or you will most likely forget what you did and you will be lost, and possibly ruin your engine by running too lean. If I have learned anything on my 5 or so months pestering people on this site and generally making an ass out of myself at least I have learned this-you will ruin your engine by running lean. At least you will burn your cylinder up. Any good pit crew will document exactly what was done to the engine. I keep a small notebook for this reason in my bucket. Remember the fuel in your cylinder does two things, it burns and it cools the cylinder. Sounds contradictory but it is true. But the extra fuel is vital for cooling. Unless you like to push your bike home.
