Author Topic: Check engine starts blinking 4 times while driving  (Read 1761 times)
spindel
« on: October 23, 2024, 10:07:43 AM »
Hi folks, have another issue with my Agility 50 2018, 6000+ km. The check engine blinks 4 times after some time when driving.
I've googled around but did not find a definitive reason for this code. Any hints what exactly this can be?
I am planning to check lambda first. Any clue how to check if it is alive?
JJJoseph
  • Kymco Sento
Re: Check engine starts blinking 4 times while driving
« Reply #1 on: October 27, 2024, 08:59:38 PM »
Some Kymco 4-strokes use the oil light to signal when it's due for an oil change. Mine starts blinking every 2000 km.  Turn it off using the key toggle.  Not all Kymcos are the same.
spindel
« Reply #2 on: October 31, 2024, 07:54:57 AM »
Will check that idea by removing battery.
But, looks like TPS honestly. The indicator starts blinking after sometime, specifically when going for some time with full gas. It can happen the light won't go off at all if I didn't open throttle fully.
JJJoseph
  • Kymco Sento
« Reply #3 on: January 14, 2025, 09:33:10 AM »
Still sounds like the oil change light.  You have to turn it off with the hidden toggle.
