Topped up the gas (using the very accurate dash gauge) and caved in to my #1 serv. gripe - got down on my back and checked the air in the tires.
I checked the plate rivetted to the scoot - "40PSI > rear". My memory isn't the best - but that doesn't sound rught.
Checked the manual: REAR - 32 PSI one rider > 40 PSI with passenger.
Well....I figure I'm about 1.5 or 1.6 normal riders - so went with 36PSI under my rear.
Then I remembered that I'd overfilled a bit on my last oil change. (put a pc of blue tape on the dash as a reminder) It was a very cold day - so I'd decided not to foolwidit.
Not my first rodeo with oil levels - so I used my turkey basting injector to draw out some oil through the fill neck to correct the level on the dipstick.*
Plugged the battery tender back in and sprayed another coat of water repellent on 3 pair of gloves for the wet ride tomorrow.
*no worries about that tube coming off and falling within the engine. I figured if anyone was prone to doing that, it would be me. So that tube is like 3' long. It's not going to disappear.
