Author Topic: The battery light is on  (Read 384 times)
Vyacheslav
« on: March 03, 2025, 06:24:16 PM »
Hello everyone. Please help. The battery light is on, but the charging is 14 volts. What happened?
Re: The battery light is on
« Reply #1 on: March 03, 2025, 08:14:11 PM »
@Vyacheslav welcome here!
Battery light (permanent) on could mean too less voltage from generator.
To test: multimeter to have
-seat tray out
-unplug this two prong connector which leads from regulator/rectifier to your battery
-start engine
-measure at this red and black cables VDC
-less than 14.5 V, we have to go further (later)
-more than 15.-16 V your reg/rec is shot
Please see link and come back for Qs.
https://www.kymcoforum.com/index.php?topic=33615.msg235978#msg235978
« Last Edit: March 03, 2025, 08:22:25 PM by Ruffus »
Vyacheslav
« Reply #2 on: March 12, 2025, 07:35:09 AM »
The voltage regulator was replaced, the charge became 14.3 volts. The lamp continues to burn
Vyacheslav
« Reply #3 on: March 12, 2025, 01:29:50 PM »
And it's strange. When I turn on the ignition, it doesn't light. After starting the engine, it lights up after 5 seconds.
« Reply #4 on: March 12, 2025, 07:25:04 PM »
Pls take a pic and post to see the real thing..
