Author Topic: Super Fever 50  (Read 1338 times)
SuperFever50
Super Fever 50
« on: January 14, 2011, 09:36:49 PM »
I have a Super Fever 50 that I cant get to start. Has no spark. Have replaced spark plug, ignition coil, and still no luck. Does this sound like it could be a voltage regulator or CDI box ??  Perhaps the stator ?   Any suggestions would be greatly appreciated.
ts1
Re: Super Fever 50
« Reply #1 on: January 15, 2011, 10:40:53 AM »
Could be...
also a blown fuse, side stand switch, brake switch, starter lock ... already checked the easy things?
Re: Super Fever 50
« Reply #2 on: January 17, 2011, 01:17:40 PM »
sometimes a clean scoot is a happy scoot.go around and clean all the wires unplug and clean the wires to the cdi box- battery- choke relays- everything you can think off.
Rianna
Re: Super Fever 50
« Reply #3 on: January 18, 2011, 04:02:22 PM »
Hi, SuperFever50!
Welcome to the forum!!
Are you trying to start it with the push start button or kick starting it?
Rianna
Re: Super Fever 50
« Reply #4 on: January 19, 2011, 02:31:57 AM »
Hey, SuperFever50, what kind of gas did you put in your scoot? Is it fresh? If it was sitting awhile you may just need some fresh gas.
You gots a good brand of spark plug??
Shaka
Re: Super Fever 50
« Reply #5 on: January 20, 2011, 11:48:53 PM »
Most likely the cdi, very well could be the stator also.
