Author Topic: Magnetic Drain Plug?  (Read 4636 times)
« on: January 20, 2011, 02:29:05 AM »
Anyone know where to get a magnetic drain plug for the Super 8 ?  With no oil filter I would feel better having a Magnetic drain plup to catch metal particles.
glopezz05
Re: Magnetic Drain Plug?
« Reply #1 on: January 25, 2011, 12:49:55 PM »
Jeremy over at Enviromoto has one.  Nice guy and a great dealer.
http://enviromoto.ecrater.com/p/9784742/magnetic-oil-drain-bolt-kit
Im usually on a bicycle, so for me, this thing is hauling ass!
« Reply #2 on: January 25, 2011, 10:56:30 PM »
Thanks, I just ordered one.
Dion
« Reply #3 on: January 28, 2011, 11:56:30 PM »
Another alternative I've been thinking of ... put a high strength magnet in the bottom of the strainer plug. I think this would work ... either in place of the part Enviromoto is offering (which I really like) or along with the magnetic plug.
The small oil capacity of scooters is a little frightening but with regular changes and especially using synthetic oil, these engines should last a long time. A little help from a few strategically placed magnets can't hurt.
Has anyone tried putting one under the strainer?
Dion - Chicago - where the streets almost thawed today. Short rides only, slower speeds but still out there as often as possible.
« Reply #4 on: January 29, 2011, 02:25:04 AM »
The enviromoto kit, which looks like it has mag plugs for the eng oil bolt, filter screen bolt and final driver bolt, is only $9.99 delivered.  Why mess around with magnets?
glopezz05
« Reply #5 on: March 06, 2011, 04:56:36 PM »
Just ordered the magnetic drain plug kit and some dr pully sliders.
Klaviator... what oil do you use for your s8 150?
« Reply #6 on: March 08, 2011, 09:22:19 PM »
I have been using Honda 10w40.  I used it because it's what the dealer recomended but will probably switch to something else on my next oil change.  I changed the oil at 165 and 500 miles.  I'll change it again around 1300.  I haven't decided yet on what kind of oil I'll use.  I'm considering Rotella 15w40 since it's what I use in my motorcycles.  The other options are Rotella 5w50 synthetic or maybe Mobil 1 synthetic.
« Reply #7 on: March 17, 2011, 08:52:16 PM »
Just changed my oil for the third time at 1268 miles.  I put in Rotella 5W40 Synthetic and replaced the drain plug and the big plug holding the oil screen with magnetic ones.  I'll report back after I ride some and see if I notice any difference.  I would expect it to start easier and maybe some increase in gas mileage.
Dion
« Reply #8 on: March 27, 2011, 02:41:08 PM »
I got the Drain Plug Kit from Enviromoto and was delighted to realize it had magnet inserts in EACH of the three  plugs. Delightful surprise. I took the kit to an automotive house, picked up some appropriate seals/ washers, and cleaned off some minor plating flash before I installed them. The screen plug was a bit difficult to fit as the magnet is a ring which pushes the screen up a bit higher than the original drain plug. Take your time when you are fitting this one as it could cross thread.
Great little addition to the bike - I think all the plugs will work on my P250 too. Which is a good thing at the high mileage on that 2 wheeled pick up truck.
Dion - Chicago
Kevin
« Reply #9 on: April 06, 2011, 08:44:27 PM »
glopezz, How'd those sliders work out for you, and what size did you get?
Also, anyone here used an external oil cooler? I live in Phoenix and ride everyday...
Cheers!
--Kevin
'09 Kymco Super 8 150 Blue 'n Yellow - first two wheeled street machine, of many to come...  :D
bucky639
« Reply #10 on: June 30, 2011, 02:44:56 PM »
sorry its taking so long to reply... I was glopezz in another forum life (HA!)
I crashed the scoot shortly after that post and didn't have the parts installed.  In fact I have only recently started riding it again and the parts are still sitting...
I'll let you know if I ever get it on there.
I am glopezz05!
dvldoc
« Reply #11 on: July 05, 2011, 02:10:20 AM »
Hard drive magnets work great for this they are about as strong as you get.  And are cheap or free.
Kevin
« Reply #12 on: July 06, 2011, 02:14:30 PM »
Hey Bucky,
Sorry to hear about your crash. You and your scoot ok?
I suppose that's the reason for the name change? ;)
dvldoc, that's a great idea! I have tons of dead drives...
--Kevin
bucky639
« Reply #13 on: July 06, 2011, 06:23:10 PM »
scoots fine, just some cracked and scraped plastics.
I changed my login because I was away from the forum for so long I couldn't remember my login and couldn't get it to send me an email to login that way.
I am glopezz05!
