Author Topic: KYMCO Venox Oil Change  (Read 6628 times)
adri
    • Motorcycle News, Reviews, Events, Roads, and Rides
« on: January 20, 2011, 06:28:20 PM »
Hey guys, posted up a page last week on how to do an oil change. Includes pictures to make it really easy for you. Also talks about what oil to use.
If you guys have any thoughts/feedback please let me know?
« Last Edit: September 29, 2011, 07:58:21 AM by adri »
Paperkrain
Re: KYMCO Venox Oil Change
« Reply #1 on: June 09, 2012, 12:52:34 PM »
Great work
Thanks for the tutorial :D
Making anymore? -How to check coolant and perform a coolant flush :D
TokiHacker
« Reply #2 on: June 17, 2012, 12:30:18 AM »
How about how to do a Carb cleaning?  :)
« Reply #3 on: June 17, 2012, 01:26:25 AM »
Got your hands full now Adri. That's the sort of post thats needed. How To's!
max oradea
« Reply #4 on: June 18, 2012, 04:34:47 AM »
dont do a carb clean unless you have the tools. at the end of a clean you will need vacumm gauge to balance the cylinders and adjust the idle mixture screw. you may strip and clean the carb. but after that take it to a garage to get the carbs balanced. cleaning and striping on your own is easy, take it apart slowly and remember where everything goes. use compress air and carb cleaner, remember to take off the diaphragm before you start to use the carb cleaner. spray every hole you can find and use compress air to clean and blow away any clog together with the carb cleaner. do not touch the air cunt off valve... no need to clean that part, and it is a little bit tricky to put that part together.
ce
« Reply #5 on: June 22, 2012, 01:44:33 PM »
I thoughght he said 'air cutoff' diaphragm, but I have an ear infuction, and I cunt hear very well.
It's a decceleration valve with a vac line to it on top of the carb, it lets the engine slow down as you let off throttle.
Albuquerque, New Mexico
max oradea
« Reply #6 on: June 22, 2012, 03:57:19 PM »
sorry guys bad spelling! but that thing is tricky! stay away!
