Hi everyone
I am about to do my first very own service on my scooter and need some feedback on a few things. I have an Agility 125, and have never done anything mechanical to anything before. But I know I can do this, I just have a few general questions and need some tips. Thanks!
First off, I am using full synthetic 10w40 at 1400 miles of riding. I need to know if this is ok, or should I stick with dino oil another several hundred miles for engine break in reasons?
Should I change the gear oil? I believe this was changed 700 miles ago, but can't be sure? It seems easy enough, and since the scooter is still pretty new, I figure it might not be necessary. But why not do it, anyway?
My manual states to CHANGE the air filter every 2000km. So it's time. But should I change it, or will simply cleaning it be ok? I would like to not mess with it at all for now, but if it's dirty I should know about it, I would think? It just seems a clean / swap every 2000km's is sort of precious for an air filter. I do all city riding, btw. It's not very dusty around town.
One of the big questions I have is about lube and grease points. The manual shows in general where these points are on the scoot but not close up (brake cable, wheel bearings, throttle cable, pivot points, etc) but when I look at these places on my scooter, I don't see anything or anywhere to lube up or grease! Everything seems covered by rubber or plastic or....nothing looks lubed or greased as it is, and I have no idea where or how to apply the stuff! Can someone please tell me or illustrate just where all this supposed chassis lubrication is supposed to go?
Lastly, I read on the forum the drain plug IS the oil screen bolt, also. And that is where the oil drains from. But in this video of a Super 8 oil change the guy drains oil from one side of the engine, and then removes the filter bolt. Now, I checked my Agility and it has the same bolt this guy drains from on the side there. Do I need to drain the oil like this guy does to get all the oil out, or will doing it from the filter bolt suffice?
Wow, thanks for reading all that guys (and Rhianna and Carol lol) and thank you much for any info, tips, and advice!
