Author Topic: my agility wont start............  (Read 1686 times)
rattle
« on: January 31, 2011, 06:55:25 PM »
my agg 50 will not start,got a good spark,when i hold my hand over the back off the carb it has plenty of suck and my hand ends up with petrol all over it(is this normal)also could anyone tell me what the thing at the side of the carb is that has the two wirers comming out of it(could that be my problem)i am totaly lost here can anyone please give me some advise......cheeers
Portland Steve
Re: my agility wont start............
« Reply #1 on: January 31, 2011, 07:33:42 PM »
It sounds like the engine turns over when you try to start it.
I have never stuck my hand on the carb while starting, but fuel goes into the carb and mixes with air, so fuel on your hand is not surprising.
The wires are probably to a sensor for the auto choke, but can't see what you are talking about.
My guess is that your carb is flooding.  Try twisting the throttle while you start to clear out extra gas.
More info would help.
Cheers
rattle
« Reply #2 on: February 01, 2011, 05:36:04 PM »
thanks for reply,the agg turns over fine i have a spark,when i remove the plug its bone dry,seems fuel is getting in carb ok,i have compression,but she will not fire up....could it be blocked jet?...i did not want to strip the carb until i have tryed the simple stuff first..... :-\
axy
« Reply #3 on: February 01, 2011, 08:08:08 PM »
Remove from the jack and connect back CDI.
Kymco Agility 125 2008
