Author Topic: Help. Engine cutting out  (Read 1114 times)
cantoa
« on: February 02, 2011, 07:54:41 PM »
Hello All,
I bought my Super 8 150 last year (October of 2010), and I got it serviced at 200 mi and 600 mi.  Over the past month, the engine would cut out during my trips to work.  I would literally try to start it back up in the middle of the street.  The problem is basically that when i let go of the throttle, the engine cuts out.  As a temporary solution, everytime I stopped at a red light, i would need to turn the throttle a little bit just to keep it from cutting out again.
Just yesterday, as i was pulling into my driveway, the engine cut out and the lights won't even turn on.  Of course, it seems like a battery issue.  Does anyone else know what is going on?  Is this normal?  Any help would be great.
glopezz05
Re: Help. Engine cutting out
« Reply #1 on: February 02, 2011, 10:38:18 PM »
maybe one of your carb jets are clogged.
but i really don't know.
Im usually on a bicycle, so for me, this thing is hauling ass!
« Reply #2 on: February 03, 2011, 02:22:35 AM »
is it cold outside right now wear you are rideing at the temp. matters a little the cold air change you well need to rejust the idle a little or the throtle screw.
