Author Topic: what is this called  (Read 2096 times)
dreflu
what is this called
« on: February 21, 2011, 03:04:30 PM »
recently started having problems out of my peolpe 2t. she would idle fine but soon as you hit the gas she'd die out. after changing the plug and playing with the adjustment screw i asked around and was told to check gas lines... and the gas stops in this thing. i changed the filter in it and still nothing. im pretty sure this is my problem. anybody have an idea what this is called and where i can get one?
ts1
Re: what is this called
« Reply #1 on: February 21, 2011, 05:19:04 PM »
« Last Edit: February 21, 2011, 05:23:16 PM by ts1 »
dreflu
« Reply #2 on: February 21, 2011, 05:47:49 PM »
dreflu
« Reply #3 on: February 21, 2011, 05:54:06 PM »
im not having any luck finding one.
ts1
« Reply #4 on: February 21, 2011, 06:37:23 PM »
I posted a direct shop link ::)
juice
« Reply #5 on: February 21, 2011, 06:44:31 PM »
stadium yamaha website : 379  SKU: 16950-KEC8-9000
AUTO COCK ASSY FUEL is a saleable item. 1 $33.98
« Reply #6 on: February 21, 2011, 06:49:58 PM »
you may be able to just hook up a normale gas filter and run it like that as long as the gas is being filtered befor it gets to the carb you should be all good.
dreflu
« Reply #7 on: February 21, 2011, 08:05:48 PM »
thanks everybody... the link wasn't in english for me... and stadium yamaha i tried but couldnt find.. im gonna call.. thanks....
juice... you alive!!
dreflu
« Reply #8 on: February 21, 2011, 08:56:15 PM »
i thought about this but its two lines coming off the carb. one to let the gas in and one behind the intake. i just orderded the part. i'll keep you all posted in case someone else has this problem
dreflu
« Reply #9 on: February 21, 2011, 08:57:52 PM »
thanks the sku is the easiest way to get to it. ive always known people to get parts from there but ebay always had what i needed............... until now
Whisper
« Reply #10 on: February 22, 2011, 03:39:18 PM »
  Make sure that critter is hooked up correctly!
  - You have a line in - Connected to the tank
  - A line out - Provides gas to the carb
  - A vacuum line - This should be connected to the intake
  It will ONLY let gas through when there is a vacuum applied to it - If you are lucky and willing to do it, you can suck on that line to see if the gas will flow.  This replaces a manual petcock (PITA) keeps the engine from flooding while the scoot is sitting.
