13 Aug 2013:
I did more of the 6000 mile service today. I inspected the brake system, suspension, tires, side stand safety switch, secondary air supply (smog) system, spark plug and checked the headlight aim.
The brake system inspection consisted of starting at the brake levers and going hand-over-hand down each brake line to the brake calipers, inspecting everything. Nothing was wrong here.
The suspension inspection consisted of checking the shocks for leakage, cleaning them up a bit, and checking bolt tightness. Nothing was wrong here, either.
The tires still look good. The light cut on the rear tire that I'd reported finding on 30 Dec 2011 has worn away. No other problems found.
The side stand safety switch inspection consisted of starting the bike, and extending the side stand to be sure it kills the engine. No problems here, either.
The secondary air supply system inspection consisted of checking the hoses and AICV (air injection control valve) solenoid for any damage. The AICV itself gets inspected and cleaned every time I take the valve cover off to adjust the valves, which I last did on 12 May 2013, so I know it's OK. Nothing was wrong here, either.
The spark plug still looks good. It's only got about 1500 miles on it, being installed on 18 Feb 2013 at 4548.6 miles.
The headlight aiming is a bit involved. First, you have to measure the height from the ground to the center of the headlight, with your tires fully inflated and you sitting on the bike... usually not something you can do with only one person, unless you get creative. I got a large piece of cardboard, tacked it to the wall, and drew marks on it in 1" increments from the floor up. Then I pushed the scooter until the front wheel was touching the cardboard, then turned on the high beam. Where the center of the beam was, I noted in my mind how many inches were indicated on the cardboard. Then I backed the bike up until the front wheel was a measured 20 feet away from where it was when touching the cardboard, and looked at where the center of the beam was again. It's supposed to be 1" lower for every 10' you back up, and it was ~2" lower, so my headlight is aligned.
Since I'm near 6,000 miles, I decided to replace the brake pads, which I'll do every 6,000 miles.... brake pads are cheap, and it's better to be safe than sorry.
I'd recently purchased 2 sets of Kevlar Carbon brake pads, enough to change the front and rear brake pads twice. The brake pads are made by Volar Motorsport, item number VMFA197.
Replacing the brake pads is ridiculously simple, and it's pretty much the same for front and back wheels... in fact, the front and back brakes use the same exact brake pads.
First, don't be alarmed by the funky fishy smell the new brake pads give off when you open the package... if you don't want your hands to stink for a day or so (even after washing your hands), wear gloves or use the Invisible Glove cream.
Loosen the two brake pad pins (the two hex-head bolts on the brake caliper), but don't remove them yet.... you want to do this first, because it's difficult to apply torque to these after the caliper has been removed from the bike.
Remove the hose clip (it fastens the brake line so it doesn't flop around as you're riding). This lets you move the caliper around more easily as you're changing the brake pads.
Remove the two caliper mounting bolts. Slide the whole caliper assembly off the brake rotor.
Use your hex wrench to completely unscrew the brake pad pins. Keep your thumb on the brake pads, as they might try to jump out as the pins are pulled through them and out.
You'll notice the brake pad pins have blue threadlocker on them to prevent them from coming loose. Clean the old threadlocker off the threads as best you can. Now would be a good time to clean the old threadlocker off the caliper mounting bolts, too.
Remove the old brake pads and inspect them and the rotor. I'll include my inspection report at the end of these instructions.
The brake caliper pistons (two small cylinders that push against the brake pads) will be extended a bit. Clean up the exposed edge of the pistons with a soft nylon brush and blow out any dust before pushing the pistons back in until they're flush with the caliper body. Just get your thumbs in there and push down on the edges of the piston. You'll have to push pretty hard, and they'll go in slowly, but they'll go. This is to give the new brake pads clearance to fit on the rotor.
Now is a good time to do a general cleanup of the caliper, the brake rotor, and any parts that you can't normally reach with the caliper installed on the bike.
Next, install the new brake pads. It's usually easiest to put the outside brake pad in (the one nearest the caliper pistons), then put the brake pad pins in just far enough to lock it in place. You'll have to push down on the brake pad to align the holes so the brake pad pins can slide through the brake pad. Then install the inside brake pad, pushing it down to align the holes as you push the brake pad pins through. Push the brake pad pins in as far as you can without having to thread them in.
Next, put a drop of blue threadlocker on the threads of the brake pad pins and screw them in, torquing them to 13 foot-pounds. Clean up any threadlocker that squishes out as you're screwing the brake pad pins in.
Now slide the whole assembly back onto the rotor, and use the top caliper mounting bolt to hold it in place. You don't have to torque it yet, just thread it in a bit to hold the caliper in place.
Next, put a drop of blue threadlocker on the other caliper mounting bolt, and put it into the bottom hole of the caliper mount. Don't torque it yet, just thread it in and hand snug it, so you can wiggle things a bit to get it all aligned.
Now take out the top caliper mounting bolt, apply a drop of blue threadlocker, put it back in, and hand snug it, as well.
Now torque both caliper mounting bolts to 19 foot-pounds. Clean up any threadlocker that squished out as you were screwing the caliper mounting bolts in.
Put the hose clip bolt back in and tighten it.
You're done with the first brake.
You may notice the first couple of times you pull on the brake lever, it'll have no resistance. That's because you pushed the caliper pistons in to give the new pads clearance to fit on the rotor. Give the brake lever a couple pumps, the caliper pistons will move out a bit, and you'll feel your usual resistance again.
Now do the other wheel, and you're done!
After you've pumped the brakes a few times to move the caliper pistons back out, you'll notice that when you spin the wheels, you can hear a slight dragging of the brakes on the rotor. This is normal. The wheel should still spin freely, it shouldn't bind, but the brake pads will lightly touch the rotor all the time.
As for my inspection report:
For the old brake pads, I measured the following:
The backing plate was 3.35 mm.
The thinnest (most worn) brake pad was 5.01 mm (not including the backing plate).
All the brake pads wore to within .04 mm of the same, so when I brake, I'm using front and rear brakes pretty much equally.
There was still 2.73 mm of wear left on the brake pads (determined by measuring the shallowest cut in the brake pads).
For the new brake pads:
The new brake pads have a slight thinner backing plate, at 3 mm.
The brake pads are 6 mm thick (not including the backing plate).
There is 4 mm of wear left on the brake pads (determined by measuring the shallowest cut in the brake pads).
Both brake rotors were fine. The rear was almost a mirror finish, the front wasn't as polished, but there were no grooves or gouging, and neither one had any discernable wear.
I took the scooter out for a test ride, testing each brake several times in our parking lot at low speed to be sure they were working properly before I hit the road. I rode to a large empty parking lot, and did ten medium-speed (25 MPH) and ten high-speed (50 MPH) near-stops (slowing to about 2-5 MPH, then riding in a big circle around the parking lot to let the rotors cool down before doing the next braking sequence) to bed the brake pads in. These new brake pads have got a lot of bite, even right out of the box, but it's very smooth and controllable. Time will tell how well they do in the wear department.
I still have to replace the fuel filter, bleed the brakes, replace the coolant, inspect the crankcase breather, and replace the variator rollers, and I'll be done with the 6000 mile service.
13 Aug 2013 (cont.)
I ordered a set of six 20x15 (16 gram) Dr. Pulley slider weights from Buggy Parts NW.
https://www.buggypartsnw.com/home?page=shop.product_details&product_id=443Dr. Pulley Slider Weight 20x15 for 125/150cc - 16g UNI-SR-20X15x6-16g
SubTotal: $29.95
S&H: $5.00
Tax Total : $0.00
Total: $34.95
And I ordered the Phoenix Systems Reverse Brake Bleeder Tool, Item #: 91083897
http://www.speedwaymotors.com/Phoenix-Systems-Reverse-Brake-Bleeder-Tool,48050.htmlSub Total: $84.99
Shipping: $7.30
Tax: $0.00
Total: $92.29
I also created a nifty little device that makes reverse brake bleeding truly a one-man job. It clamps to the master cylinder, with a tube that dips down into the brake fluid. That tube runs to a glass jar with a sealable lid. Another tube runs out of that jar and into a special aquarium pump that can draw a suction. Now as I'm pumping brake fluid in at the brake caliper, I no longer have to monitor the master cylinder brake fluid level to be sure it doesn't overflow. As the master cylinder brake fluid level rises, the suction will pick up any brake fluid over whatever level I set, and deposit that brake fluid in the glass jar. See the attached picture. Yeah, it's rough-looking, but it'll do the job.
So when I get around to bleeding the brakes, I plan to use my suction device to suck out all the brake fluid from the master cylinder reservoir, then pump fresh brake fluid in at the calipers until it completely flushes out the old brake fluid. Then I'll carefully top off the master cylinder, and do a forward bleed by pumping the brake lever (with the bleeder hand pump reversed and hooked up to the caliper to act as a check valve so air can't get back into the brake line). In this way, I reverse bleed to force air up and out, then forward bleed to flush the master cylinder piston.
14 Aug 2013:
I replaced the fuel filter, and inspected the crankcase breather.
This consisted of removing the seat, Met-In box and front panel under the seat. After those were removed, I put down a rag on top of the gas tank, then unscrewed the hose clamps for the old fuel filter, slipped it off, and dropped it into my oil drain pan while I hooked up the new filter and tightened the hose clamps. A quick wipe with a clean rag to get any spilled fuel, and the fuel filter was done.
Then I disconnected the crankcase breather tube, started the bike, and watched. If white smoke comes out at any time, it means the piston rings are worn, stuck or broken. If nothing comes out, it means the crankcase breather is clogged and needs cleaned. Fortunately, it's working just fine. I also drained the crankcase breather tube drain (that clear tube on the left side just ahead of the oil filter). A lot of water and one large chunk of white snot came out.
As I had already disassembled the Met-In box, I decided to take a peek in the battery compartment, since the battery had previously barfed battery acid all over. And sure enough, it did it again, just not as bad as last time. So I disassembled everything, washed it clean, and reassembled. I'm beginning to think the battery's doing that when I go into the extreme lean angles as I ride. As luck would have it, the new battery arrived later in the day, so I dropped the new battery in. The new battery is just a tiny fraction of an inch wider and taller than the old battery... it fits into the battery box with absolutely no room to spare. It's not so tight that you can't slide it back out, but it's exactly the same size as the inside dimensions of the battery box.
Oddly, the lumpy idle when cold and occasional hard starting (having to crank it for around 3 seconds, instead of instantly starting as it did when new) have gone away. I have a sneaking suspicion the old battery was failing, causing a lower-than-normal voltage, which made the charging circuitry try to charge it, which caused the battery to boil. Or it could be that I lean the bike until it scrapes. :)
I still have to replace the coolant, bleed the brakes, and replace the variator rollers, and I'll be done with the 6000 mile service.
15 Aug 2013:
I replaced the coolant today. First, I had to figure out how to prevent the coolant from getting all over the insulation I'd just wrapped on the exhaust pipe. I got a plastic bag and tied it around the exhaust pipe, then stuffed the excess in between the engine and exhaust pipe. If you do this, be sure to remove the plastic bag when you're running the engine. You don't want to be scraping melted plastic off your exhaust pipe.
I drained the old coolant, flushed some distilled water through to get out as much of the old coolant as I could, filled with tap water, ran the bike for five minutes to circulate it, drained it, filled with distilled water, ran the bike for five minutes to circulate it, drained it, filled with Valvoline Zerex Asian Vehicle 50/50 Premix, ran the bike for five minutes to circulate it, drained it, then filled it again with Valvoline Zerex Asian Vehicle 50/50 Premix. Following the service manual instructions, I kept the radiator cap off each time and I snapped the throttle open a few times each time I ran the engine, to flush out any air bubbles.
All told, when I was finished, I had a gallon of old coolant, water and new coolant that'd been flushed through the system.
I also removed and washed out the overflow bottle. The hardest part was getting to it... you've got to remove the bottom Tupperware at the front to get to the overflow bottle, and it took me a while to figure out there's two screws, one on each side, hidden beneath the body panels directly behind what I was trying to take off. Bend those body panels out and down a bit, get your screwdriver in there and loosen the screws, and the Tupperware comes right off.
The old coolant had a thicker than water consistency and was a dark green. It was clean, though. The new coolant has the consistency of water, and is pink.
In another thread (
http://www.kymcoforum.com/index.php?topic=3649.0), I'd done a lot of research to find a coolant that would work with our scooters, and Zerex Asian Vehicle fits the bill.
After running the bike on the main stand long enough that I was satisfied there were no more bubbles in the system, I buttoned everything back up, and took it out for a test ride. I stuck within a couple miles of home on 35, 40 and 55 MPH roads, so if it overheated I could shut down and push it home. After 45 minutes of riding, it was still running fine, so I headed home.
I still have to bleed the brakes and replace the variator rollers, and I'll be done with the 6000 mile service.
