Author Topic: how do you test a stator  (Read 4036 times)
« on: March 08, 2011, 02:07:11 AM »
how can you test to see if your stator is working.
mjcharger
Re: how do you test a stator
« Reply #1 on: March 08, 2011, 05:13:01 AM »
I got this off of a repair manual I have for my Agility 125. Hope this is what you wanted.
A.C. GENERATOR CHARGING COIL INSPECTION
Disconnect the A.C. generator 2P connector.
Measure the resistance between the A.C.
generator white wire and engine ground with
an electric tester.
Standard: 0.2~1.2Ω(at 20℃)
Replace the A.C. generator charging coil if
the reading is not within the specifications.
A.C. GENERATOR LIGHTING COIL INSPECTION
generator yellow wire and engine ground
with an electric tester.
Standard: 0.1~1.0Ω (20℃)
Replace the A.C. generator lighting coil if the
« Reply #2 on: March 08, 2011, 10:14:00 PM »
thanks I did check it out I took the stator wire of started the scoot then put a light tester on the yellow and whit wire and the light came on so all is good. lol I found out later all I need to do was replace the rings around the carb and tighten theam down good.
mjcharger
« Reply #3 on: April 21, 2011, 06:22:40 AM »
Did you get any numerical values when you tested the stator with the engine running? Or did you just start the scooter and test for a complete circuit?
