Author Topic: electrics problem and air filter  (Read 2638 times)
ste4239
Re: electrics problem and air filter
« Reply #15 on: March 15, 2011, 06:13:05 PM »
PS woodcutter many thanks for the link
woodcutter
« Reply #16 on: March 16, 2011, 12:14:09 AM »
To change engine oil look in chapter 4 in service manual, and for transmission in chapter 10.
Everything is described with pictures.
As I understood, you said you put engine oil into transmission, or?
What roller weights you installed and is there any improvement in speed?
For engine, use 15w-40 or 10w-40 (if you can't find 15w) grade oil.
If you use mineral, change it at max 1000km (in summer at max 500-600 km)
and semi-synthetic at 2000 km.
For transmission use SAE 90 grade oil.
« Last Edit: March 16, 2011, 03:03:18 AM by woodcutter »
