Author Topic: Where to buy Boss Drive Unrestricted???  (Read 2564 times)
macocoy
  • Sting/yup 50 2 stroke(2009)
« on: March 12, 2011, 09:37:50 AM »
Only one question,where to get unrestricted boss drive Spacer?
Scooters r big boys toys-
Tecnigas next r,malossi variator,1000 clutch torque spring,Uni open air,
sparko
Re: Where to buy Boss Drive Unrestricted???
« Reply #1 on: March 14, 2011, 08:30:54 PM »
I live in the US and I bought from these people who are very helpful. I have heard of lower prices elsewhere but at 35 dollars shipped I am ok as their web site is informative for a novice like myself. Nice people and everything works just fine. If you call them they will talk you through the purchase procedure.
http://www.scootertherapy.com/advicepage1.html
macocoy
« Reply #2 on: March 14, 2011, 11:47:57 PM »
Thanks so much,finally I got the help I need.do you know how to derestrict exhaust,I heard there's a washer the needs to be drilled out.I have the Yup50 09..Aloha
sparko
« Reply #3 on: March 15, 2011, 01:42:18 AM »
Haven't done the washer on my super 9 but someday soon. I believe you take the exhaust off and it is basically welded inside the exhaust pipe. it is there to restrict airflow so drill it out with a drill or a dremel but if you bought your bike used it may already be taken out. Probably need to rejet but check the forum with a search. I did a search and this one looked informative
http://www.kymcoforum.com/index.php?topic=2150.msg18343#msg18343
good luck 8)
macocoy
« Reply #4 on: March 15, 2011, 02:08:27 AM »
Thanks again Sparko I just ordered it,I guess the pipe thing is harder than I thought,safe drivin..
0BARK4322
« Reply #5 on: April 07, 2011, 11:36:08 PM »
THE BOSS DRIVE CHANGE IS EASY TO DO AND YOU WILL SEE A BIG DIFFERENT----GRRRRRRREAT
ALL STOCK
macocoy
« Reply #6 on: April 07, 2011, 11:53:44 PM »
Thanks Obark,I put on a mallossi variator with the not restricted boss,it's been great.I am now on the exhaust part.My stock exhaust has a Cat converter,just wondering where is the best place to buy tecnigas next R.(best price).And main jets for the stock carb?
