Author Topic: need help bad  (Read 1020 times)
CONLEY
need help bad
« on: March 12, 2011, 04:50:11 PM »
okay so im in the middle of my 150 swap got motor in need to wire it up
my scoot is a 08 a50 motor is from a roketa mc17 150
problem the a50 stator has 3 wires white yellow and a blue with yellow tracer
donor motor has 5 wires got to check on the colors but anyway can i buy a stator for a 150 with 3 wires or just leave two diconnected
also will i have to use my cdi or the one from the donor bike please help i need it lol
Re: need help bad
« Reply #1 on: March 12, 2011, 10:31:43 PM »
Do that big of a swap you may have to do a new wire harnes swap to. I think you may have a extra gound wire or one that gos to the cdi box.  im not sure on this but you can trace all the wireing to see wear they go. it may just that you have to find out wear all the extra wires go. wireing a scoot can be a real pain wish you luck. tri to find the wireing diagram for the 150 and go from there.
CONLEY
Re: need help bad
« Reply #2 on: March 13, 2011, 12:16:40 AM »
yea thats what im thinking blue
found the diagram from the donor but you cant blow it up to read it
what i did do was cut out the entire wiring harness from the donor and looked at the diagram from the a50. found some things in comon shouldnt be to bad
talked to scooter mike from scooter tronics he said that i will have to go with the donor cdi cause the kymco one is dc not ac. found out there not to far from me either.
anyway i guess i got some more work and more parts to order wish me luck
