Author Topic: CDI Cut and Fuel indicator  (Read 938 times)
fjoerto
« on: March 12, 2011, 09:35:29 PM »
I just cut the cdi wire and i dont now but, now the fuel indicator is showing empty all the time. When i turn the key on, then the fuel indicator should move to full, but no luck.... Does anybody know what might be wrong? I tryed to connect the wire againg just to see if have something with the cdi wire....Looked for loose connections and things like that, but no... any other suggestions?  :-\
Re: CDI Cut and Fuel indicator
« Reply #1 on: March 13, 2011, 12:39:23 AM »
if you have a agilty 50 there is no wire to cut you cut the box it self.so maybe you cut wrong wire.
« Reply #2 on: March 13, 2011, 12:40:16 AM »
also check the fuse next to the battery.
fjoerto
« Reply #3 on: March 13, 2011, 03:04:36 PM »
Fixed, nothing to do with the cdi cut, i filled full tank and the float mechanism was stuck... Just bad luck, hehe :)
