Author Topic: tick over problem, please help :(  (Read 1208 times)
kymco God
« on: March 17, 2011, 07:45:22 PM »
i have got the kymco super 8 50cc, and it runs fine, but, when i slow down and stop, it will just slowly die, and turn of (when the choke is of), basically it doesnt idle when stationary. is this a problem with the idle jet, or the cdi unit? if this is the problem, where can i get a new one?
thank you for your help
(btw the choke works fine).
ts1
Re: tick over problem, please help :(
« Reply #1 on: March 17, 2011, 07:58:27 PM »
Carburetor adjustment:
warm up
adjust mixture screw to max rpm
adjust idle screw for robust idling
kymco God
« Reply #2 on: March 17, 2011, 08:12:38 PM »
thanks, where are they on the carb though
ts1
« Reply #3 on: March 17, 2011, 08:37:06 PM »
4-stroke:
mixture screw #16154, idle screw (without number) above #16142
http://www.kymco-ersatzteile.de/shop/catalog/default.php?cPath=101_1579_1834_2020
If you have the new 2-stroke, it's #20 and #10
http://www.kymco-ersatzteile.de/shop/catalog/default.php?cPath=101_1579_2935_2944
kymco God
« Reply #4 on: March 18, 2011, 10:04:13 PM »
thanks for your help, how much do i adjust the mixture screw too?
cheeers :)
ts1
« Reply #5 on: March 18, 2011, 10:39:10 PM »
Mixture screw about 2-3 revs outside all-in, to the position which results in maximum idle rpm. Just try!
But I forgot:
If the valve clearance was checked long ago, you should do this prior to carb adjustment. With cold engine!
kymco God
« Reply #6 on: March 19, 2011, 09:56:56 AM »
will the choke still work properly when it is started from cold though? (auto-matic choke on this scooter btw). and it doesnt really like and throttle when the choke is on.
cheers :)
ts1
« Reply #7 on: March 19, 2011, 10:03:49 AM »
You don't touch the choke with valve clearance or carburetor adjustment, it will still work.
The choke is basically a heated bimetal slowly closing an additional jet.
